Based on my calculations, as of right now I've pumped 9750gal since I've started. I'm gonna pump through until morning and take some readings tomorrow. By 8:25 I should have pumped 14250, which is over 80% if it were an even swap.
You really can't take a measurement unless you mix the water. Otherwise it will high in the areas of old water and low in the area of new water. I would base it on the last measurement you made and the amount of water you added since you stopped remixing the water.Based on my calculations, as of right now I've pumped 9750gal since I've started. I'm gonna pump through until morning and take some readings tomorrow. By 8:25 I should have pumped 14250, which is over 80% if it were an even swap.
