Thread: Should I run the Polaris while SLAMing?
    gablueliner's Avatar
    Aug 2013
    Guyton, GA
    26
    I'm in the process of SLAMing and there is no more green stuff in the pool. Everything is now just murky and there is dull grey sediment on the bottom of the pool. Should I be running my Polaris while SLAMing to keep the water churned up or should I let everything settle and vacuum?
    36K gallon IG vinyl; pool frog system; Sta-Rite Cristal-Flo II Sand Filter 70GPM; Sta-Rite 1HP Pump; Polaris 280 w/booster; build date June 2013; TF-100.
    Re: Should I run the Polaris while SLAMing?
    It is best not to put the Polaris in the pool while SLAMing. If vacuuming looks to be important you could manually vacuum, or wait until SLAMing is complete.
    Aug 2013
    Guyton, GA
    26
    Thanks. I will carry on with the SLAMing and stick to vacuuming.
