Results 1 to 12 of 12
Thread: My new high-tech chlorinator
    Mar 2014
    Atlanta, GA
    34
    For those of us too lazy to hold a bottle of chlorine for more than a minute. Price: $18 more or less. Having a drink while it dribbles in for 15 minutes : priceless.
    New at pools. 23k Gallon pool - 36x17 ft grecian, vinyl. Pentair TA60 sand filter with new valve. Hayward superpump. Booster pump for Polaris 280C.
    Casey's Avatar
    SW PA
    10,461
    Re: My new high-tech chlorinator
    Pics or I'd didn't happen.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    I love it!
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Sweet!!!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Nice.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mar 2007
    Murrieta, CA
    215
    That's a great idea. I may do something similar for muriatic acid.
    ~13500 gallon gunite pool, Pentair Intelliflo 4x160, Pentair 520 SF cartridge filter, Pentair MasterTemp 400 NG heater
    Pentair Easytouch with IC40 SWCG, Hayward Navigator on dedicated suction line
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    605
    Brilliant!
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Necessity is the mother of invention. Well, and lazy too...lazy has invented lots of things. LOVE it! Off to see what I have lying around to do something similar.
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Mar 2014
    Atlanta, GA
    34
    Yep, thanks all. You can see how lousy a PVC mechanic I am. I dump as much bleach in as I need, then dilute it as it goes in. I had to put some rocks in the bottom to counter balance, and put that lid underneath to keep the gravity going my way. It's working just great, though.
    Jan 2014
    CA
    24
    For adding dry acid, I dissolve it into a bottling spigot. I added a plastic tube at the spigot. Flow can be controlled and it works very well. It should work for chlorine too.
    Link
    Mar 2014
    Atlanta, GA
    34
    Excellent idea. My husbands beer making supplies are in Virginia, or I definitely would have used that!
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by BeckyL View Post
    I bet he wishes you had, then he'd have an excuse to buy kegging equipment.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
