Thread: Opening pool test question.
    May 2014
    Saint Albans, WV
    50
    I've got a TF-100 test kit and am opening pool for first time. What are the main tests i should run to ensure my water is good to go. Thanks in advance.
    10.4K gallon 21' round Elixir AG
    Hayward 150lb Sand Filter/1.5 Hayward Pump/Hayward Diver Dave cleaner
    Pool installed 7/11/14. TF-100 Test Kit.
    Re: Opening pool test question.
    At the start of the season you want to run the full set of tests. The only exception is that if the pool was just filled there is no need to do a CYA test.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Here is some basic info on water chemistry, ABC's of Pool Water Chemistry. And Recommended Levels
