Thread: Just opened and looking for a little help getting the water balanced
    May 2012
    Allentown, PA
    219
    It has been I while I could use some help. Not exactly sure what order to go in.
    FC-0
    PH-7.1
    TA- 70ppm
    CYA- 20
    Salt-2200
    Water looks slightly cloudy, but I can see the bottom at 8'. Where there is dirt from coming through the rain vent on the winter cover it looks slightly geenish on the bottom at that spot.
    23,000 gallon vinyl liner with SWG
    Thanks
    21,500 Gallon Vinyl liner pool Eastern Pennsylvania
    Hayward 2 HP pump 2" Pvc pipes Full Sun Pool
    Hayward sand filter, Compupool CPSC 48 SWG
    12mil solar cover and reel
    Re: Just opened and looking for a little help getting the water balanced
    First priority is to get some chlorine in there. Then raise the PH a little bit. And then start on raising CYA up, but don't go all the way on CYA in one go, adjust perhaps 2/3rds of the way, wait a week, test, and adjust from there.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,202
    Jason beat me.....
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Things are just a teeny bit below what we recommend for CYA and pH, but you're close enough. With the cover off, you're getting sunlight in that pool, and slightly cloudy is going to be impenetrable in a couple days if you don't kill that algae, and fast. With 20 CYA, shock level is 10. Get some bleach in there ASAP, and check it again every couple hours and keep it there. If you have any powdered shock lying around from years past, you could use that to raise the CYA a little while you raise FC. But what's most important is killing that algae before it starts reproducing. A gallon today could save five or ten by Monday.
    Complete instructions are in the SLAM article.
    May 2012
    Allentown, PA
    219
    Thanks for the tips. I have it up to shock level and brushed the whole pool.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Excellent. Keep it at shock level as much as possible without fail.
    Essential Links:
