Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: CYA too high?
    Apr 2015
    Weatherford/Oklahoma
    11
    CYA too high?
    I am new to testing my own water. Twice I've tested my CYA using the CYA view tube until the black dot disappears. Both times it never reaches the 100 mark, meaning it is well over 100 ppm? It is an above ground pool with a vinyl liner. I would really rather not change out 75% of my water, and getting the water level too low and I would have to worry about my liner. If I did my math right it would cost about $85 on my water bill for about 10,000 gallons. My pool volume is about 16,400. I dont think there is a R/O service in my area. I'll have my local pool store test it and see what level they say it is. Anything I am missing?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: CYA too high?
    Trust your testing. If you have read around here much you have probably seen that not much credence is given to pool store testing. While you would think that a "professional" would be the best, unfortunately in most cases it is quite the opposite. Between employees who blindly trust the word of chemical sales representatives and high school kids working in the pool store for the summer you end up with poor results from their testing.
    100 is the limit of the CYA test, so you have to do a diluted test. While the full instructions are in the Pool School, here is the short version. Mix 50% pool water with 50% tap water. Use this mixed sample as your test water. If still at a 100 you will need to dilute more. Here is a great chart by JamesW to explain dilution rates and what you multiply the results by to get an approximation of your CYA level.
    Pool water......Tap or distilled water.........Multiply result by
    ....1...................1................................2
    ....1...................2................................3
    ....1...................4................................5
    Support the site
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,464
    Re: CYA too high?
    You can do a 1:1 tests for you water. One part pool water, one part tap water. Do the test that way. Double your results and you will have your CYA level.
    How have you been treating your water? Pucks or bleach?
    I understand about not wanting to mess up your liner BUT I am here to tell you that high CYA can mess up your liner and equipment so..............
    What you can do is drain and fill several times so that you do not lower you water too much at any one time.
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: CYA too high?
    Are you saying the black dot disappears before you get to the 100 mark? Then your CYA is whatever the number is where the dot disappears.
    Here are videos of how to do the tests.
    https://www.youtube.com/user/tf100te...e=results_main
    Jun 2011
    Long Beach, CA
    2,784
    Re: CYA too high?
    Welcome to TFP cue!
    Follow tim5055's advice on testing the CYA. The CYA test is the test which pool stores are the worst at. Using the dilution method above will give you the closest reading that the test can do. The test is exponential so the reading could be much much higher than 100.
    With high CYA the best option is almost always to replace the water. RO services are a lot more expensive than replacing water.
    There is a new product that just got released to the public to reduce CYA, but if the CYA level is too high to start with that product will be a lot more than to just replace the water.
    Apr 2015
    11
    Re: CYA too high?
    Ok, did some more testing. Just to make sure I did this right. I took 5ml pool water and 10 ml of tap water (at room temp), this got me to the bottom of the label on the red cap bottle. I then filled to the top of the label with the reagent. Shook for 30 sec. I then added the solution to the CYA view tube and got to just a hair under 100. So my CYA is 300 ppm? I have been using chlorine tabs for the last 4 years. If I change my water out and get my CYA in line and if I continue to use the tabs I have on hand which will likely take this entire season. Will I be in the same boat as I am now, with the high CYA?
    16,400 gal Above Ground Vinyl Liner, Hayward Sand Filter, 1.5 HP Power Flo Matrix Pump single speed,
    Pentair In Line Chlorinator with 3" tabs (switching to bleach) TF-100 Test Kit. Pool is approx, 4 years old. Western Oklahoma
    May 2014
    Franklin, NC
    9,184
    Re: CYA too high?
    Quote Originally Posted by cue View Post
    You can go to Pool Math and plug in your numbers and down at the bottom you can see what the effect of common chemicals will have on your pool.
    It would help us help you if you would add the following information to your signature
    • The size of your pool in gallons
    • If your pool is an AG (above ground) or IG (in ground)
    • If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass
    • The type of filter you have (sand, DE, cartridge) and, if you know, the brand and model of the filter.
    • If you know, please tell us the brand and model of the pump, and mention if is it a two speed or variable speed pump.
    • Date of pool build/install, particularly important if less then a year old.
    • What kind/model of water test kit you are using
    • Other significant accessories or options, such as a spa , SWG, or cleaner
    Support the site
    Apr 2015
    11
    Re: CYA too high?
    I've added the info. So assuming Im going to have to replace water, how far can I lower the water level at one time without messing up my liner?
    Jul 2012
    Tallahassee, FL
    30,464
    Re: CYA too high?
    Yes you will. The pucks and any "shock" you have added in the past 4 years adds CYA.
    CYA=balance or stabilizer. If you look on the labels you will see they will say something about it.
    On TFP we use chlorine/bleach to keep out pools clean and clear.
    Some of us use pucks for long weekends and vacations. We make sure we know how high out CYA is and keep track of how the pucks will affect our levels and go from there.
    Kim
    30,419
    Re: CYA too high?
    As a guideline, we suggest to always leave a foot or thereabouts of water in the shallow end.
    I think it makes the most sense to drain 1/3, then another third, then another if necessary.....refilling and testing after each drain.
    I know it's painful now but you have to bite the bullet and ABSOLUTELY get off the pucks as your primary source of chlorination.
    Apr 2015
    11
    Re: CYA too high?
    ok. Its in the process of draining now. Thank you for all the help, we will see were I end up at tomorrow evening.
    May 2014
    Franklin, NC
    9,184
    Re: CYA too high?
    Keep us posted. To keep things in context please keep posting to this thread as things progress.
    Support the site
    Apr 2015
    11
    Re: CYA too high?
    Ok. I replaced about 75% of my water and refilled. I am now at about 110 CYA from 300. Using the pool calculator it says I need to drain another 60%. How much will the CYA drop on its own?
    May 2014
    Franklin, NC
    9,184
    Re: CYA too high?
    CYA naturally drops a few (yea, that slow) points a month. The biggest way to drop cya is to pump water out of the pool whenever you get rain. I started with 200+ CYA and over the course of a year now have it to 60. I did make an adapter to harvest water from one of my roof gutter downspouts. A good rain would raise my level a few inches, then I would circulate it for a while and pump it back down to normal level.
    Evaporation will not reduce CYA.
    There are a few threads going now relating to a bioactive CYA reducer. So far the results are mixed, but you can take a look at them.
    Support the site
    Apr 2015
    11
    Re: CYA too high?
    I'll just drain and be done with it. Good idea on the rain water.
    38,275
    Re: CYA too high?
    That is the best ... and likely cheapest path forward
    Welcome to TFP!!!
    Apr 2015
    11
    Re: CYA too high?
    I drained about 50% of the water and refilled last night. Re-checked CYA and I am now at 65-70 PPM. A couple of questions about testing method. Do you add the solution to the view tube and as soon as you can no longer see the black dot, that is your reading? Or can you add some solution let it settle a few seconds, look away and continue adding solution until you absolutely can no longer see the dot? If I take the intial reading it is at 100. If I let it settle a few seconds etc.. Its at 65-70.
    Prolly splitting hairs, which I tend to do, over thinking things. So assuming my level is in the 65-70 range. What should I do from here? Leave it and let it come down on its own? We will be getting quite a bit of rain for the next few weeks, and its not typically warm enough to swim until closer to June.
    Or drain more?
    38,275
    Re: CYA too high?
    You can let it settle to allow any air bubbles to dissipate. Also you can pour it back and forth to get a few reading to see if it is always the same.
    I would say that 65-70ppm is manageable ... especially if you are going to get a lot of rain dilution. You just need to maintain the adequate FC level from here on out. See: FC/CYA Chart
    What does the water look like?
    Apr 2015
    11
    Re: CYA too high?
    Total Chlorine is 3 and PH is 7.5. Water is crystal clear (it is pretty much all new water) Water temp is 60.
  20. Back To Top    #20
    38,275
    Re: CYA too high?
    You FC is too low. It should NEVER be below 5ppm. So you should dose to about 8ppm every day so that it never drops below 5ppm by the next day.
