Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: friend said: "the bleach threw the alkaloids through the roof." huh?
    Jul 2012
    Herndon, VA
    419
    friend said: "the bleach threw the alkaloids through the roof. Tomarrow the acid to kill the bi carb cloud.
    Any idea what he's talking about? alkaloids?
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: friend said: "the bleach threw the alkaloids through the roof." huh?
    No, I don't have an alkaloid test. I might go google it in a minute.
    Total nonsense.
    Jul 2012
    Herndon, VA
    419
    Quote Originally Posted by JasonLion View Post
    Total nonsense.
    any idea at all what he's referring to, or trying to refer to?
    There is a story that gunite/plaster pools leach alkaloids into the water, which doesn't really fit and isn't true anyway.
    Bleach is often blamed for raising the TDS level, which is just as true of all other forms of chlorine.
    All I can imagine is some kind of blending of these two myths.
    Jul 2012
    Herndon, VA
    419
    I asked him: "Alkaloids? what are you referring to? how do you test the level of alkaloids?"
    his response:
    "Simple titration or dip strip. Alkiloids are bicarbs. When chlorine is in a solution, it binds to organics and forms hyopcloris acid(i'm butchering the spellings). As the hypocloris acid rises in solution, large amounts of chlorine is needed to break down the hypo chloris acid. Part of that reaction produces positive hydrogen ions. They react with the sodium and carbon in the water and form ni carb. I put a huge amount of sodiun hypochloride in water that was full of organics and now its cloudy because the level of bicarb is through the roof."
    anyone?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Back to Jason's original statement, Total nonsense.
    If he is a good friend, talk to him about anything but pool care. You can change the subject by taking him down to Jimmy's Tavern in old town Herndon.
    Support the site
    Jul 2012
    Herndon, VA
    419
    Quote Originally Posted by tim5055 View Post
    this is a facebook conversation. Have you been to Jimmy's in Herndon?
    Well, half of each sentence is correct this time. Nothing here actually makes sense, but there are numerous sentence fragments that are taken from the actual chemistry.
    Alkaloids have nothing at all to do with bicarb.
    All forms of chlorine in solution form hypochlorous acid, which is the chemical name for the disinfecting form of chlorine.
    Positive hydrogen ions are always present in the water. They are not created by these reactions.
    Hypochlorous acid bind to organics and for combined chlorines (there are several types). Additional chlorine binds with combined chlorine to break it down further. Again this is true for all forms of chlorine.
    Sodium and carbon don't directly participate in these reactions, though they may be a part of the organic material that is reacting, or may simply be present in the water.
    These reactions end up producing mostly water, salt, and nitrogen gas. Bicarb is not involved, either as a reactant or as a product.
    Generally, if you "put a huge amount of sodium hypochloride in water that was full of organics" the water will clear up. However there are some (rare) situations where the water could cloud up, though this has nothing at all to do with bicarb. The most likely route for clouding up would happen because bleach is basic, i.e. raises the PH, and then lowers the PH as it breaks down. It is possible for that short period of high PH to cause calcium clouding.
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by GuinnessPhish View Post
    Lived in Vienna for five years, yes - loved Jimmy's
    Support the site
    Jul 2012
    Herndon, VA
    419
    more from friend:
    "Before I started, the bicarb levels were 40 ppm. I just tested it, i'm at about 190 and probably going to go higher. Bicarb cloud"
    "Already slammed it with enough to reach break point in a 30,000 gallon pool. I was only treating 2000 gallons. 1/4 gallon muariatic tomarrow and the pool wil be balanced for swimming by noon"
    Just nonsense. Stop listening, though perhaps you might pretend to listen if you want to appear polite.
    Jul 2012
    Herndon, VA
    419
    my friend works at a pool store.
    "I am going to be opening and closing close to 1500 pools this season as well as making about 3000 weekly stops. I don't do the actual labor but my 16 techs follow my recepies to the letter."
    Jul 2012
    Herndon, VA
    419
    "you want me to post the link that says smoking cigeretts is healthy.... The water tempreture is about 55 degrees nlt to mention its only reading about 20 ppm. Its too cold for any calcium to drop out and make a cloud. Ph is dictated by alkalinity. Starting with rain water (no calcium in that) and only adding bleach to the water, I got an increase of over 150 ppm of bicarb in the water. The only thing that could have raised it was the liquid chlorine"
    Casey's Avatar
    SW PA
    10,444
    Shake your head yes n keep moving along, right over to Jimmy's.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Be polite I suppose.
    Essential Links:
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    Your ability to keep from rubbing your eyebrows off while listening to this dribble will be increased exponentially by the percentage of alcohol content of the adult beverage you hold and your use of a straw to consume said beverage.
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,772
    Phish, if you want to have some fun, ask him if he's using test strips
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Quote Originally Posted by Swampwoman View Post
    Or, ask him how much time he's been spending with his head too close to the open muriatic acid jug!
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
  20. Back To Top    #20
    umpalumpajay's Avatar
    Dec 2014
    West Hills, CA
    157
    These arent the alkaloids you're looking for.
    12000g pool + 1000g spa. Jandy 2.0hp epump + separate Jandy pump for Sheer Descent. Jandy CV Cartridge Filter. Jandy Lxi gas heater. Tropical Breeze PebbleTec. Aqualink. Aquapure SWG. Nature 2. The Pool Cleaner 2x. Taylor K-2005.
