Thread: Stenner 45MHP10 flow settings FYI
    Apr 2015
    TX
    32
    Not complicated math, but I thought I may save somebody a few minutes by posting this.
    Here are the ounces of chemical the pump will inject per hour at the different settings. Determine how much chemical you need to maintain your FC daily, and then you can run your pump at the listed settings to get yourself there.
    Setting 1 = 5.33 oz per hour
    Setting 2 = 10.67 oz per hour
    Setting 3 = 16 oz per hour
    Setting 4 = 21.33 oz per hour
    Setting 5 = 26.67 oz per hour
    Setting 6 = 32 oz per hour
    Setting 7 = 37.33 oz per hour
    Setting 8 = 42.67 oz per hour
    Setting 9 = 48 oz per hour
    Setting 10 = 53.33 oz per hour
    14,800 gallons in-ground vinyl. sand filter. 1.5 hp pump
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Stenner 45MHP10 flow settings FYI
    Great information, Thanks!
    Support the site
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Will the flow rate go any lower than setting No. 1 at 5.33 oz/hour? That is a daily rate of 1.0 gpd and that pump is supposed to go as low as 0.5 gpd.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    22,544
    The Stenner adjustable pumps have an "L" setting that's half of the "1" setting, so that's how they get the GPD.
    I created a spreadsheet for determining how much is injected per length of run time at the different settings, but this software won't let me attach it here.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Thanks for posting that it's good information. Will save me some time.
