Results 1 to 9 of 9
Thread: Ocala, FL Pool and deck renovation
    ahampleman's Avatar
    Nov 2011
    Ocala, FL
    30
    My pool renovation starts on Monday the 20th. I'm going to have new tile and Diamond Bright finish along with brick pavers installed over the existing deck. Already had the neighbors Live Oak trimmed back, so that it no longer hangs over and dumps in the pool. I will update with pictures daily.
    21,500 gallon outdoor in-ground 16'x32' Diamond Brite Cool Blue pool. Sta-Rite SuperMax 1.5 HP 2 speed pump running on low for 8 hrs a day, Sta-rite PCX125 cartridge filter, CircuPool RJ-45 SWG, 500 watt incandesce light, 1 skimmer, 4 returns, Dolphin Oasis Z5 robot cleaner, Solar-Breeze NX & TF-100 test kit, Taylor K1766 kit with speed stir.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Ocala, FL Pool and deck renovation
    Awesome! Looking forward to see it all done!
    Divin Dave,
    Sep 2013
    Charlotte, NC
    41
    Cool! I will follow this reno.
    26K gallons, IG vinyl, Pentair 1.5 HP, Hayward DE filter, TF 100 test kit, Ecojet Turbo Cleaner
    ahampleman's Avatar
    Nov 2011
    Ocala, FL
    30
    Well the reno has started today. Pretty boring day , as the only thing that happened was the coping overhang was cut off and the pump dropped into the bowl. Nothing picture worthy. The thunderstorms this afternoon was more interesting.. Tomorrow the new tile will go in. Will update with pictures then.
    Casey's Avatar
    SW PA
    10,446
    Can't wait to see it transform!
    ahampleman's Avatar
    Nov 2011
    Ocala, FL
    30
    Pictures from the coping overhang being cut, demo of a ramp coming out of the screen room and the new tile.
    Attachment 35579
    Not sure why the pics did not show in the order I want.
    Today they are laying the coping, building the new step and starting the paver deck.
    ahampleman's Avatar
    Nov 2011
    Ocala, FL
    30
    Question Re: Pool and deck renovation Ocala, FL
    Well the coping is in and grouted and the old finish has been chipped out and bond coated. The new step to the porch is under way and some of the pavers have been placed. Not a lot will happen till after the new Diamond Bright is installed on Wednesday. I think the tile on the pool steps will happen Monday.
    The conduit on the back of the light niche had been sealed up (I guess from a old leak) . Should I chip out some of the old epoxy and put some new in there? Any thoughts ?
    ahampleman's Avatar
    Nov 2011
    Ocala, FL
    30
    Well I chipped out the old epoxy in the niche and put a wire cork in it then butyl sealer around it all. The step tiles where set today.
    I'm now being told that the finish got bumped to Thursday do the forecast of RAIN for the next 2 days..
    ahampleman's Avatar
    Nov 2011
    Ocala, FL
    30
    The Diamond Bright was finished Thursday. Friday it was acid washed and fill hoses place in the bowl and started to fill at 8am. Saturday morning at 5 it was full, PB was here at 7am to do the start up. Been brushing and cleaning the filter waiting for the water to clear, and chasing the PH. Will post pictures once the water has cleared and the pavers are complete.
