Results 1 to 8 of 8
Thread: One year old K2006 kit.
    Jun 2013
    Springfield MO
    51
    Will it still test accurately after 12 months? Just opened today and my CYA is hardly readable and last year I was around 40. I think I need to add stabilizer for my chlorine to kill the green beast.
    KGK
    23K, IG Vinyl, Sand Filter, 1.25 HP
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: One year old K2006 kit.
    If you kept it inside, it should be fine
    Jun 2013
    Springfield MO
    51
    Okay, What would cause my stabilizer to drop so much of the winter?
    KGK
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Water replacement on re opening could be a factor, but I can't see where you are. Also common would be the condition of your pool. Did it get Green on you? How much did everything else drop off or otherwise change?
    Please post a full set of test numbers, and let's see what all is going on.
    Essential Links:
    Jun 2013
    Springfield MO
    51
    Okay, my CYA is showing 10. Last year it was 40. No water level changes since last season. My pool temperature is 59 degrees. Does that matter on CYA readings?
    PH - 8.0 +
    I am trying to keep my pool at 12 ppm (Shock level), but it is dropping so fast. Within 1.5 hours it dropped from 12 to 2.4.
    Pool is cloudy Grayish Green and hasn't changed in 2 days with 12" depth visibility. Suggestions?
    KGK
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Next time FC is under 10 test the ph and adjust it.
    Please update your signature and location as described here, What we need to know to answer your questions
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by KGK View Post
    PH - 8.0 +
    Yes, complete a SLAM procedure to the letter. This will fix it. The link to that is in my signature line. Ask for help with it, we will be glad to lend a hand.
    Essential Links:
    38,354
    Loss of CYA + High chlorine demand could point to ammonia conversion. Are you seeing high CC levels too?
