Results 1 to 16 of 16
Thread: Cloudy pool and slam
    Apr 2014
    Lumberton,nc
    20
    Ok guys I need make sure I'm doing things right. We opened pool few days ago and saw little algae. We slammed it on Thursday and the water is still little bit cloudy. Here were my readings today:
    FC. 17
    CC. 0.5
    PH 7.6
    TA 80
    CYA 100
    CH. 40
    Is the high cya the reason why the water is cloudy or am I not giving this enough time?
    23k,IG vinyl,vs Hayward pump,sand filter,SWG, built 4/14
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Cloudy pool and slam
    You're not giving it enough time. The SLAM is a process that could/should take anywhere from several days to several weeks.
    At the same time, the common CYA test reports any CYA level over 100 as 100, so your actual CYA level might be quite a bit higher (or not).
    I would lower CYA down to around 80, which would make the SLAMing process quite a bit easier.
    Apr 2014
    Lumberton,nc
    20
    Ok another question do I keep fc at 17 or let it start drifting back down? And as far as my pump does it still need keep running 24/7?
    Thanks guys
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Quote Originally Posted by arieyellow View Post
    Thanks guys
    First, re-run the CYA test using the dilution method explained in this thread. Post 8, note 9.
    Second, re-read the article on the Shock Level and Maintain process. You need to get the FC level up to shock level for your CYA and keep it there until you pass all three criteria. 17 FC is not high enough if your CYA level is above 40!
    If you're keeping up with testing FC & CC, you'll know when the CC is below .5. That's one of the three.
    When the water is clear even after brushing, and there's nothing growing on the walls, you've passed two.
    Then you run the overnight loss test. If it passes, then you allow FC to drop. If you fail, you add more bleach.
    A sand filter is the slowest of all to clear the cloudiness. It can take a week or more. A lot depends on how vigorous a strain of algae you have, how religious you are with brushing it, and how often you test and replenish the chlorine. But when you're done, your pool will be so sparkly you will be the envy of all the neighbors. You'll be able to toss a quarter in the deep end and spot heads or tails from the deck.
    Check out some stories of others who have done it.
    Apr 2014
    Lumberton,nc
    20
    Ok so basically keep the chlorine raised to shock level for now and don't worry about cya? Or do I stll need go ahead and drain pool some to lower cya while still shocking?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    You don't have chlorine at shock level for your CYA level. Chlorine CYA Chart. Rerun the extended CYA test per Richard's instructions, then lower CYA to around 80 per Jason's instructions, then resume SLAM by maintaining FC at shock level per this Chlorine CYA Chart.
    Clear as a green pool?
    Apr 2014
    Lumberton,nc
    20
    Ok now I am understanding. What puzzles me is cya was perfect Thursday before I shocked with liquid bleach. What caused it to rise so high?
    DFW, TX
    24,497
    The only thing that causes CYA to rise is by adding CYA or using pucks or shock with CYA. When is the last time you added? How much did you add? Did you wait a week after adding to test? It takes about a week to fully register on the test.
    What test are you using?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Yes, what test kit are you using, or are you getting it done at the pool store?
    Support the site
    Apr 2014
    Lumberton,nc
    20
    I'm using the fas-dpt test and the only thing added to the water before I shocked it was some kind chlorox brand stuff from walmart to up the ph.
    DFW, TX
    24,497
    What test are you using to test CYA?
    Apr 2014
    Lumberton,nc
    20
    The one that is in that fsa-dpt kit
    DFW, TX
    24,497
    Fas-dpd is a chlorine test, not a cya test. Is it the CYA test kit in this video?
    https://www.youtube.com/user/TF100TestKit/videos
    Apr 2014
    Lumberton,nc
    20
    Sorry I was looking at the wrong name on my kit lol. I have the taylor 2006.
    DFW, TX
    24,497
    Hey, alright! No worries, that is a good kit.
    I'm trying to go back and read through to see what your CYA is. But, I'm not sure. What were the last couple of tests? When and what result?
