Results 1 to 8 of 8
Thread: Hooking up new pump before opening
    Jun 2014
    Bloomington (Minneapolis), MN
    110
    Hi all, I need some help with a new pump. My old one went out the end of last season and I had a local small engine repair place replace it with the pictured pump.
    The hookups are different and I'm not sure how to connect it. I included photos of the old pump hooked up, the wires, and the new pumps connections. Any help appreciate!
    ImageUploadedByTapatalk1429368505.909086.jpgImageUploadedByTapatalk1429368520.801628.jpgImageUploadedByTapatalk1429368527.053031.jpg
    Pool: 28K gal, vinyl lined, rectangular, auto cover
    Equipment: Mineral Springs MS-10 SWG, Raypak 266A heater, Jandy CL460 cartridge filter, Pentair superflo 1hp 2spd pump, Polaris PB4-60 booster pump and Polaris 280 cleaner. TF-100 w/speed-stir
    Jun 2014
    110
    Re: Hooking up new pump before opening
    Do you know if your pump circuit is setup for 120 volts or 240 volts?
    Jun 2014
    110
    Quote Originally Posted by JasonLion View Post
    I'm not sure, is there a way to tell?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Yes, there is a way to tell if you understand electricity. I recommend that you call an electrician or pool guy to install your pump. It is not worth the risk.
    Jun 2014
    110
    Quote Originally Posted by pooldv View Post
    Sounds good. Thought it would be as easy as hooking the wires back up. Oh well.
    DFW, TX
    24,483
    Yeah sorry, the wire colors aren't matching up and it seems like you need more electrical instructions than I can give to get it all to make sense. Better safe than sorry. Better luck on the next project!
    Jun 2014
    110
    No worries, I appreciate you taking a look. Just hate having to pay for the pool guys to look at stuff, they charge so much.. I'm sure the next project won't be far off haha
