Results 1 to 7 of 7
Thread: Searching for a fitting...
    I'm trying to make a hot water fill for a customer. He has an existing water spigot, and I'm trying to run CPVC from that location to another valve about 20 feet away.
    Problem is that every 3/4 fitting I try does not seal adequately with the spigot - it always drips. Hose fittings; pvc to water hose adapter; 3/4 brass fittings ; 5/8 fittings ; with washers ; without washers . You get the idea. The rest of the plumbing is fine , but I've emptied my tool boxes and most of the part bins on this one connection with no success
    Any ideas ????
    21K gal, IG plaster, 1/2 HP WhisperFlo pump, 60 sqft Titan RPM Vertical Grid DE filter
    30,402
    Re: Searching for a fitting...
    A "pvc to spigot" adapter is common and the few I have used work well. You may have an oddball spigot and need to replace it.......hard to say.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I'd suspect bad threads on the hose bib, too.
    30,402
    +1 what 320 said!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I don't think so.
    Water hose connections are not a thread seal, so I wouldn't agree its a thread problem. If there is enough thread to screw the fittings together tightly, the seal will be made on the face and gasket.
    Never had a problem with a hose to NPT conversion.
    Essential Links:
    After further investigating --- And thanks for all your replies, everyone was so helpful! ---
    I think that this spigot is simply an oddball -- I am going to try a few more tricks, but I may end up just replacing the spigot. I will update with solution...
    Can't emphasize enough how helpful you all were - I was too busy to reply during the day - but, this forum rocks!
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    I've seen situations where the hose fitting nut threads onto the bib, but it's leading edge of the nut hits a part of the casting and prevents the nut from fully tightening even though it feels like it tightened. The rubber washer isn't fully compressed and you get a leak. The casting interference from the faucet is usually on the underside so you have to bend down and look carefully from a low angle. I've only seen that problem on oddball faucets but that may be what you have. Use a file to clear away the interference and get that nut to tighten further.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
