Results 1 to 16 of 16
Thread: Panic (should I?) rust on gunite!
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    I haven't had time to post new pictures on our pool build, but I woke up this morning to rust (looks like rust) running down the gunite walls (gunite on Thursday) in a couple of places. I don't recall seeing this on any other pool build threads.
    Is this bad, or just part of new gunite before plastering? I'm trying not to panic, and hopefully my concern will turn out to be a good laugh. Posting 2 pictures below. Thanks in advance - Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    30,431
    Re: Panic (should I?) rust on gunite!
    It appears to be coming from returns into the pool, correct? If so, I would ignore it as your pool water will not be rusty. I have no idea where it came from......might not even be rust. Point it out to your PB and ask him the source.
    Apr 2015
    Houston, Texas
    3,217
    Ok, thank you Duraleigh. I'll send him the photos. Suz.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    To me, there seems to be wayyy to much of it to be rust. Suz, if you guys have been getting a lot of rain like we have here a 200 miles north of you, then its probably stains from red clay soil.
    Quote Originally Posted by SuzfromTexas View Post
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    I was thinking that too, except I don't think there is red clay in Houston. Pretty sure it is all black clay. Don't see how there could be that much rust though. Maybe they backfilled with some sand or something with red clay in it.
    Apr 2015
    Houston, Texas
    3,217
    Man, we really have been getting the rain! You can see the amount of water in the deep end just from Thursday night. And it's not coming from the water hose!!! I didn't even think about it being from the soil. I've lived where the soil/clay is really red, and ours isn't the same. But, our soil here must have more red to it than I realized, because the backed up pond at my back door is almost the color of the streaks in the pool.
    I feel much better thinking it's probably just the red clay soil. A good lesson, though... I certainly don't want that to run into the completed pool!!! Earlier, I did text those pictures to my pb, and I'm sure he will get back to me when he can. I feel like if it were serious, he would have already been knocking on my door!!!
    Thanks again, and here's to a healthy balance of sun and rain!!! Suz
    DFW, TX
    24,502
    Yep, good news! That sun and rain combo sure is making the grass grow!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    yeah, and the ground is so wet, I can't mow it!
    Quote Originally Posted by pooldv View Post
    Im sure its just soil stains.... nothing to worry about.
    once the pool is plastered and finsished, there wont be any way for that to happen.
    Divin Dave,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Whatever the cause, it won't be a need to panic. Once you're done and plastered, no worries.
    Essential Links:
    Household6's Avatar
    Sep 2013
    Fayetteville, NC
    296
    Curious, what did your PB say?
    BEAUTIFUL pool BTW!
    20x40 in-ground concrete "vintage" pool
    Approx 35k gal
    Concrete, plaster and epoxy paint
    Sand filter
    DIY plaster resurface repairs completed 6/2015.
    Apr 2015
    Houston, Texas
    3,217
    Thank you! At this point, I think beauty is in the eye of the beholder!!
    Our PB pretty much repeated what the people said - yellowish, brownish clay. I've crossed it off my worry list. Take care! Suz.
    Apr 2013
    Kansas
    22
    I'm a novice with just a novice opinion... but thought I would visit your thread since you did mine!
    I think others in here with experience can better advise on this, but I think I would keep an eye on weather and plan your plaster job carefully around that. You may need to plug off your returns to make sure it stops adding to the stain. And then I think you want to make sure that staining is removed before you plaster to prevent it possibly leaching through your brand new plaster job. It would be great if other posters far more experienced than I commented on that. Maybe there is nothing to worry about. Or...
    Apr 2015
    Houston, Texas
    3,217
    Thank you so much! You've raised some very good points I hadn't considered or had put to rest. I'll put this back on my list and discuss again with our PB.
    I've been wondering why... If the soil is leaching through the returns now, why it wouldn't continue later. Or is that because the returns are only "stubbed out" (correct term?)?
    I've also been concerned about the stains leaching through to the new finish.
    I do hope some more people will respond. Thanks again drgnslayr for getting this thread back up. Take care! Suz.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Suz,
    the stains are entering from around the returns because they arent sealed off well. When the plaster guy comes, they will seal off around all the wall penetrations during the process. No worries about that.
    drgnslayer does make a reasonable point about stains coming through the plaster. Rest assured this will be addressed too. By FAR, you pool is not the worse stained prior to the plaster process. Those guys DO NOT want any staining like that coming through, because it will be out of their back pocket to fix it.
    I think you should mention it to the PB, but don't loose any sleep over it like you did when the stains first appeared! It will be just fine. I promise!
    Divin Dave,
    Apr 2015
    Houston, Texas
    3,217
    Thanks, Divin Dave. No, I didn't quite put it back on my worry list. But I had put it totally out of my mind. So I'm glad drgnslayr brought it back to my attention. I do need to be watchful.
    I'll hold you to your promise! If it doesn't work out, you owe me a gallon of Bluebell Homemade Vanilla when they begin deliveries again!
    Thanks for the reassurance! Suz.
    Apr 2015
    Houston, Texas
    3,217
    Thanks to you guys, I talked to the PB's supervisor about the stains. He had time to go into a little more detail than the PB had the day I asked him. As ya'll said, he told me the plaster (aggregate?) guys will do a lot of prep work before they begin to do the finish. He said they will smooth out any rough spots, fill in the weep (?) holes used for ground water, and do a total acid wash to get off all stains. He was impressed with how much I know (or buttering me up), so I told him I owe it all to TFP!
    Pictures: For those of you reminding me to add more pictures..... I thought I would get to it today, but the cats have shed most of their fur over the last few weeks (yes, my cats are almost naked now!!!), so I'm catching up today on some desperately needed vacuuming. Even the cats were coughing, sneezing, and begging me to vacuum. Poor things.....
    Pictures coming soon. Take care! Suz.
