Results 1 to 15 of 15
Thread: New guy from Louisiana
    Mar 2015
    Baton Rouge, Louisiana
    19
    Hello!
    Totally new to pools, have been following the BBB method since I moved into my house in December. Sparkling clear water from day 1.
    Only issue I have with my pool (so far) is its missing a few coping clips, the clips that cover where the two pieces of coping meet. I have an older vinyl liner pool with the aluminum coping and I just can't seem to find a place to get these clips. Any one know a place???
    44,000 gallon IG vinyl liner pool. 1.5 hp single speed motor on E Z flow pump/sand filter. Unknown age of pool, Kreepy krauly vacuum, Taylor K-2006 Test Kit.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: New guy from Louisiana
    Can you post a pic of the clips and the coping you have? Believe it or not, there are several different shapes of aluminum coping.
    Divin Dave,
    Mar 2015
    19
    sure will let me get one....
    Mar 2015
    19
    I'm at work so I couldn't get pictures of my pool, but these I found online and are similar. I think its refered to as "bullnose coping"
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    It's an idea but you could try and find a piece of PVC pipe the same size inside diameter and cut it the same width as the clip. Then cut a section out of it horizontally so you can snap it on the coping. It might be a little thicker than the aluminum but it would do the job.
    Welcome to the forum fellow Lousisianian!
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Mar 2015
    19
    Thanks, and that's a pretty good idea. thanks! PS whats your water like? 76 here, swam today a tad cold!
    Casey's Avatar
    SW PA
    10,448
    Great looking pool!
    Oct 2012
    604
    We are at around 78. Not quite ready yet. We hit 84 two weeks ago before all the rain. Had too much going on to swim.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Hey, welcome to TFP!
    Seems we are getting more and more from LA all the time. Good to have you with us. Enjoy the forum.
    Essential Links:
    Casey's Avatar
    SW PA
    10,448
    Quote Originally Posted by ComputerGuyInNOLA View Post
    I wish my pool was at 78! I'd be swimming!
    Oct 2012
    604
    Casey, maybe I am just getting old but I have to be at least at 82 to swim. My wife wants it at 86. I hate waiting for those
    last few degrees!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    I'm old with you, 85 min and 87 preferred by me and wife.
    Mar 2015
    19
    Up to 80 today!!
    Oct 2012
    604
    We hit 84 yesterday. Spent all day in the pool. I was so excited to swim I forgot to put sunscreen on. I will pay for that.
    Mar 2015
    19
    I have a beginner question I can't seem to find an answer to..... When do you SLAM? I understand when you see algae, cloudy water, or CC over .5. but what if your water is crystal clear, with 0 CC, but using a high amount of chlorine daily. Right now i'm good, i'm only burning approx. 1 ppm daily, but if that goes up will something else change to indicate a SLAM is needed?
    Also, Louisiana People, with our weather with a CYA of 50 how much on average should I be losing a day before I get worried?
