Results 1 to 8 of 8
Thread: PVC Fitting into Filter
    Jun 2014
    Satellite Beach, FL
    5
    Hello,
    I had to remove the salt generator to clean it(another issue) and I think I may have knocked something loose. Now the black piece going into the filter seems loose. No matter which way I screw it I can't get it to stop leaking water when I turn the pool back on. I'ts not just a leak the the water is coming out bad. I will attach 2 pictures so you can see the setup. The close-up one of the black piece(not sure what it's called) is what won't screw in and is leaking at the opening to the filter. Any idea what I did and how can I fix this?
    Thank you,
    Julie
    11,900, IN, plaster, Pentair Clean&Clear 200 SqFt model #160318 150 GPM,
    Pentair 3HP variable spd 011018, Build date: 03/28/2014, SWG.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Re: PVC Fitting into Filter
    Hi Julie,
    yikes! I hope we can easily fix your leak. That black thing you say is leaking, is called a Union.
    There is a rubber O Ring inside there and the O ring should seal off the water flow when you tighten down the nut. The nut is the part you turn to tighten it up.
    If the O ring isnt seated properly then it will leak bad. There is a groove in there that the rubber O ring seats in.
    Also, we recommend to use a silicone based lubricant to lube up o rings before putting it all back together. The lube helps keep the o ring in good shape and assists in being able to tighten the nut.
    That is the first thing i would check
    The next thing, is that it may be that you simply did not tighten the nut tight enough? The have to be pretty snug. If you have a big pair of channel lock pliers, that should do the trick, but dont over-tighten.
    Divin Dave,
    The SWG might be pulling it out of alignment, which might make the nut hard to get started. It might be easier to remove the SWG, get the union at the filter tightened down, and then put the SWG back in more carefully than last time.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Yup. Jason makes a good point there.
    Divin Dave,
    Jun 2014
    Satellite Beach, FL
    5
    Thanks for the info. I will work on this today.
    Jun 2014
    Satellite Beach, FL
    5
    Thanks again. I took off the Salt water generator again and was able to get the pipe in place better. Still seemed to have alot of lubricate. No more leaking!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Excellent! Glad you got it fixed!
    Divin Dave,
