Thread: Quick question about pool
    Jan 2015
    Stillwater, OK
    10
    Thanks for all the information on this site, it has helped me turn my green pond from a foreclosed house into a blue oasis. I am almost there! I have a question that has perplexed me for a while. I have three return lines into the pool, but the middle one (pictured below) was never pushing out water. My wife and I plugged the other two, and still nothing. This led me to put a hose into the pool end of the return line, and it popped off the cap of the pipe in the picture of the pump. The pipe is to the left of the return and inlet pipes. It seems like it is an isolated pipe that runs from the above the ground and straight into the pool. My question is why?????? Thanks!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Quick question about pool
    Welcome!!
    I have a similar line, but mine is capped at both ends. The pool builder installed it in case an additional line was needed for a pool cleaner. I went with a robot, so the line sits unused. Not sure why they put a return eyeball on yours.
    Support the site
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    My thoughts are pressure side cleaner too. Eyeball added for visual appeal.
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    +another, has to be a cleaner line.
    Welcome to TFP! Great job on your pool! That was NOT pretty!
    Here is some info on updating your signature and location, What we need to know to answer your questions
    Jan 2015
    Stillwater, OK
    10
    Ahhh, it all makes sense now! Thanks everyone for the replies, appreciate it. Pooldv, I will update info, thanks!
