Thread: Could you paint the outside of the pool black
    drmac22's Avatar
    May 2013
    Swisher, Iowa
    35
    I am in the process of building a solar collector/heat for my above ground and it got me thinking.. I wondered if you could paint the outside of the aboveground pool black to help maintain the heat in the pool? Maybe a stupid thought but anyway to help with the heating of the pool would be awesome and it was just a thought. What do you think?
    Retired Navy Chief (CTOC)
    21ft round 4ft AG 9367 gallons, floater with pucks as needed, Waterway PB 19inch Sand, Waterway PB 1hp SPL (not sure of type), Rheem LP Heater, Hayward Aqua bug, Aqua Luminator Light. Located in Iowa.
    Re: Could you paint the outside of the pool black
    It would help, but the effect will be so small you probably wouldn't be able to tell the difference.
    Casey's Avatar
    SW PA
    10,438
    The sun beats on the bottom side of my pool and it gets so warm. I can feel the heat from the inside.
    Nectarologist's Avatar
    Apr 2015
    New York
    427
    The vast majority of heat loss is through the water surface. I would put the money into a solar cover to keep the heat in at night. That being said it won't hurt and if you like the look that's a bonus. Just make sure you use a paint that is for outside and can withstand direct sun. I'd be afraid it would peel or blister if it was just indoor paint.
    -Chris
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
