Thread: dark plaster calcium stains
    Apr 2014
    Bakersfield, California
    24
    Pool was re-plastered May 2014 with colorscapes dark grey. In November, CH went to 700 and white calcium stains began to appear on pool surface. Drained pool and refilled in November to lower CH. Tried Leslie's scale & stain remover for a couple months with no results.
    How can i remove these calcium spots without draining pool and acid wash?
    Is there a no drain acid wash method or product that will be effective in removing calcium stains?
    Here are my current pool chemistry readings:
    FC=2
    PH=7.5
    TA=60
    CH=260
    CYA=50
    20K gal colorscapes dark gray plaster, no SWG, BBB method, variable speed hayward ecostar pump, pentair cartridge filter, hayward navigator cleaner.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: dark plaster calcium stains
    If you're history looks like that it's not indicative of calcium scaling. Certainly not a lot of potential. That's just a snapshot, so I can't say what else has happened. Still, those are good numbers from a scaling potential standpoint.
    Any chance you can throw up some photos and more history?
    Essential Links:
    There are chemicals that can prevent additional scaling, but they are far less effective at removing scale once it has already formed.
    I don't recommend a no-drain acid wash. It shortens the lifetime of your plaster more than needed, takes quite a while, requires bypassing the heater (if you have one), and often doesn't end up working.
    If the white areas are very localized you can sometimes remove them with local application of muriatic acid (through a piece of pipe). But that quickly becomes impractical as the area affected gets larger.
    Unfortunately, a full drain manual acid wash is by far the most effective approach.
    Jan 2013
    Friendswood, TX
    320
    Could a prolonged time with a lower than normal PH remove the stains if they are light?
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    38,271
    How could your CH possibly have risen to 700ppm in 6 months? Especially given that you have now had water in it for 5 months and the CH is only 260ppm?
    That does not seem normal ... unless you were adding a lot of cal-hypo chlorine powder.
    How are you testing your water?
