Results 1 to 8 of 8
Thread: Need a new cartridge, a little unsure on replacement model?
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    147
    I am heading into my second pool owner season. My cartridge needs replaced, the previous owner ran his for 2 years prior to last summer and its really bad. Anyhow I am searching around for a replacement and can not find the exact model match up.
    My cartridge is a Hayward this is what it looks like, I suppose I was thinking it would say something like Model# 11111A but instead its a little odd.
    http://imgur.com/Ertdfiv
    I am guessing it is a C-1750E?
    The one selling on Amazon says "Fits hayward star clear plus cartridge filter model c1750" but none of them end with an "E" do you guys think they are one in the same?
    Sorry I know this is kind of a annoying question.
    Thank you!
    In ground (installed 2000), fiberglass, cartridge filter, Pentair Super Flo Single speed pump (2014).
    Re: Need a new cartridge, a little unsure on replacement model?
    Do you know the model name/number of your filter?
    Mar 2013
    CT
    348
    There should be a metal plate on the side of your filter. Find the model number and call Pleatco. They will hook you up.
    http://www.pleatco.com/
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    I am a BIG fan of pleatco filters. They are a lot better than my oem Pentair filters. Easier to clean, better flow, clog less, last longer and the pool is just as clean either way.
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    147
    This is the only thing on my filter,
    http://imgur.com/HiH5gdk
    And nothing is checked off.... of course.
    Mar 2013
    CT
    348
    If you call Pleatco they will have you measure the filter and come up with the right cartridge. They will hook you up. Trust me.
    Oct 2014
    Magnolia TX and Watford City ND
    40
    Based on your pictures, your filter model is the C1750 because your filter is the 175 sqft size. Using the filter finder tool on Pleatco.com the part number is PA175.
    25K IG gunite pool / PebbleTec plaster / 2HP Hayward 2 speed pump / Hayward 525 SQ/FT SwimClear Cartridge filter / Tiger Shark QC robot / TF-100 test kit / Stenner pump X 2 - Chlorine and Acid
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    147
    Thank you everyone!
