Results 1 to 8 of 8
Thread: How to winter cover with deck?
    Feb 2015
    Bardstown KY
    139
    I've enjoyed looking at the many pool install/deck build threads, and I've noticed that most decks seem to have the top rail sitting snug on top of the deck. Is that just how it looks in the pictures, or are they really constructed with such a tight fit?
    I think it looks great like that, but I don't understand how the pool would be covered for winter if the deck is built that way. I thought the cover tucked around the top and then had a big bungee cord type strap around the pool to hold it in place?
    Rain is preventing our dig from happening, so I'm thinking of everything else I can while I wait {im}patiently.
    27k gallon 33' round, partially buried 22" Sandman sand filter, 1.5hp 2 speed TidalWave pump, Pentair 'Lil Shark with leaf canister, TF-100 Test Kit
    Casey's Avatar
    SW PA
    10,461
    Re: How to winter cover with deck?
    I left a few inches from deck to top rail so the cover could go on n I could remove the top rails for future liner replacement without having to crawl under the deck. I ain't getting any younger. lol
    Jul 2012
    Chicago, IL
    358
    My pool came with the house so I did not set it up this way, but the deck around my AGP is over the railing by perhaps 4 inches and then they used 2x4s on their side so the 4" part is the face to cover that gap. This looks very nice and also leaves a small gap that is just large enough to slide the winter cover through. However, it requires crawling under the deck to do so, which is a pain, and with even the smallest amount of settling, the gap closed enough this year in one spot where I could not fit the winter cover without cutting the wood slightly. Further, I am going to have to replace my liner this season, which means I am going to have to remove those "face" pieces and hope that it gives me enough room to remove the top rails. You really only need a gap the thickness of the winter cover (plus a little safety margin would help) to get the cover on. The ability to remove/access the top rails is another story.
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    linda1's Avatar
    Mar 2010
    Western Pa.
    300
    We built our deck even with the pool railing but left about 1 to 1.5 space to slide edge of cover into.
    Then we bought a new cover that came with rubber bungee straps and we drilled small holes into the edge of the deck that the bungge straps hook into. This way there is very little weight on the sides of the pool. Our deck goes completely around the pool, so it works out well for us.
    30 ft. round Conquest agp, 19,800 gal; Pentair Easy Clean 1 hp DE EC60 filter system
    Hayward H250N gas heater; TF100 Test Kit
    2 Fafco 4x20 sunsaver solar bear solar panels
    Dolphin E 10 ~ Zoomerang slide
    Majestic 8000 Above-Ground Pool Step
    Feb 2015
    Bardstown KY
    139
    Wow Casey -I am originally from Greene County PA and that pic looks like home to me!
    Casey's Avatar
    SW PA
    10,461
    Quote Originally Posted by BellaBuggy View Post
    Don't you know it! That is Brownsville and the Mon River! If you want to see more pics, hit up the PM n I'll get you on FB. You can look at home all you want.
    May 2012
    Montville NJ
    545
    My deck sits about an inch or so below the bottom of the top rails. I have no problems putting on the winter cover. As long as I can get the cable into that slot, the cover holds just fine.
    The issue is going to be replacing the liner. I did not build the original small deck to that height (I did build a larger deck to match the existing). I *think* I can get the screws out of the top caps with a small ratcheting 90 degree screwdriver. If not, then I am going to have to pull the deck boards.
    An other nice bonus about having that inch of so space means I don't have to mask the top rail when I stain the deck. I can just cut in under the rail with a brush.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    mariane's Avatar
    May 2012
    Southeast Michigan
    305
    We have a patio stone deck that goes around 1/3 of the pool. When the landscapers put it up, we made sure they left a couple inches of room so we could get to the liner and put on the winter cover. In one spot, the brick is so close to the rail that I had to wrestle the cover thru. Now, we put part of the cover on the deck and hold it down with the sand tubes used to hold the ladder down. The rest of the cover hangs over the rails and weighted down with water filled jugs. Not pretty but effective.
    16 x 28 Doughboy Mystic Garden AGP with 7' deep end (used expandable vinyl liner) ~11,800 gals. Deep end main drain. Thru-the-wall skimmer, one return at deep end. Media Master 150# sand filter. Doughboy PowerPak II pump, 1 hp. Pentair MinimaxCH 150m natural gas heater. Polaris 65 when it feels like working . TF-100 test kit. No longer 'pool stored' 6 years and counting. In sunny but fickle metro-Detroit.
