Results 1 to 12 of 12
Thread: Can these stains be scrubbed off (pic)
    Apr 2015
    Southern Cali
    30
    I have a high CYA level of 200. I'm assuming these purple stains are are result from that?? Not sure, but I will be draining my pool soon and wanted to know if these stains can be removed with scrubbing the sides of the pool with a stainless steel pool brush or is there another method? Will these stains dissappear if I get the CYA levels down to 30-50 ?https://flic.kr/p/sa8gz3
    16,000 gallon, IG, Plaster, pool and spa.
    Apr 2015
    Southern Cali
    30
    Re: Can these stains be scrubbed off (pic)
    Sorry, can't seem to get the pictures to load on here.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Are you sure those are stains, and not the original color showing through worn off paint?
    High CYA didn't cause anything like that in my pool, and I started with it about 240 when I took over the maintenance.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Richard beat me, but not stains from CYA. I also had 200+ CYA with no staining. It does look like wear to the surface or etching of some sort.
    Support the site
    Apr 2015
    Southern Cali
    30
    It's also on the sides of the tile where the spa pours out and into the pool. It's like a tough chalky substance.
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by mendez4047 View Post
    Calcium scale, maybe?
    Support the site
    Apr 2015
    Southern Cali
    30
    Purple cyanurate maybe?
    May 2014
    Franklin, NC
    9,184
    I've never heard of it, but this guy has and wants to sell you a bottle of metal & stain control.....
    He claims it's caused by high CYA (which you have), copper in the water (do you?) and high TA & high pH. Have you tested for copper?
    Support the site
    Apr 2015
    Southern Cali
    30
    Haven't tested copper yet. I'll do it this weekend.
    Apr 2015
    Southern Cali
    30
    Quote Originally Posted by tim5055 View Post
    That's how I came up with my guess about purple cyanurate because that's exactly what my pool has.
    Apr 2015
    Southern Cali
    30
    Did a copper test today. Zero copper in the water.
    Apr 2015
    Southern Cali
    30
    I will be draining my pool this weekend. Should I acid wash? or can this be scrubbed off? anyone?
