Thread: Pump noise
    MJCP's Avatar
    Sep 2007
    Michigan
    129
    Pump noise
    The only label on my pump is on the motor and it is an A.O. Smith Motor 1Hp It is at least 5 years old
    My pump is making a noise it never made before, if I had to guess I would think it was a bearing squeal. It is not all that loud or irritating "Yet". Just a bit worse than a hum. But definitely not the way it sounded before.
    The pressure may not have changed at all, but it may be lower. It is at 14psi and everything else is cleaned and backwashed. My system normally runs at 15-18psi. When the filter needs a backwash it gets to about 23psi. Anything lower than 15 (usually 10 -15psi) tells me to clean the pine needles out of the impeller.
    Can the bearings be lubricated?
    Is this the beginning of the end for my pump?
    Can I ignore it till it gets too loud to tolerate?
    Is there something else I should check or suspect.
    Thanks for any help
    15x32 Lazy L Inground / Concrete - 20,000 US Gal 1979 build
    1.0Hp Maxiglass/ Sand Filter, 7th season with Pool
    Painted cement finish repainted 2011
    400,000 btu Pentair Master Temp NG
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Pump noise
    Hard to say... but 1 thing to check is underneath the pump where the motor joins the housing for a leak, while the pump is running, which would indicate a bad shaft seal assembly which is a common cause for bearing or shaft oxidation and therefore 'squealing'. The bearings can be repacked, it takes a special tool and I have no idea how to do it, but I do know that sometimes the repacked bearings last for years and other times they only last a few weeks I'd check for seal failure - if you see water under the pump, change the seal assembly before the damage gets any worse - if no drip, let it ride for now.
    Luv& Luk
    -Ted
    MJCP's Avatar
    Sep 2007
    Michigan
    129
    Re: Pump noise
    Thanks for that,
    No sign of a leak, I removed the pump housing band, and separated the housing to clean out the impeller ( it wasn't clogged). It was difficult to get back together, I've done this many times before and don't ever remember having problems getting it back together though. I lubed the O rings and put it back together then checked for leaks. Again the noise is not actually a squeal it is more like a high pitched rubbing noise, higher in pitch than a hum, but more like a scraping at high RPM.
    If there isn't a way to lubricate the bearings I will probably just ignore it for now, since the end of the season in Michigan is already here. But next season I am afraid that if the pump dies in the middle of my Start Up it might push me over the edge, unless next seasons start up is easy thanks to the BBB method
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Re: Pump noise
    Quote Originally Posted by MJCP
    Yes
    Yes
    Yes
    No...
    Factory Warranty Station for:
    Apr 2008
    Central Texas
    326
    Re: Pump noise
    I replaced the bearings in my pump about a year and a half ago. If you're handy, it's a pretty easy job. The bearings cost around $22 and I installed a new shaft seal for another $11 while it was apart. You have all winter to work on it. 8)
    It's way cheaper than a new motor and if you screw it up, it was broken anyway.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    MJCP's Avatar
    Sep 2007
    Michigan
    129
    Re: Pump noise
    Thanks all
    I found where to buy the bearings and a new seal,
    Another Winter Project - Can't wait!
