Thread: Persistent water quality problems [VIDEO]
    Apr 2015
    Helsinki, Finland
    9
    The surface of the water looks like it has pollen/oil/grease/foam on it. What is that? Is it organic/non-organic?
    Here is a video of me refilling my CalSpas hot tub with fresh water and immediately the surface of the water looks filthy: https://www.youtube.com/watch?v=Jmme...ature=youtu.be
    Here is another video from a few weeks ago: https://www.youtube.com/watch?v=n4t-_TDB1Nk
    It's a 2010 CalSpas hot tub located in Finland. I've been using AquaFinesse and chlorine to maintain the water. There was a foam problem from summer 2014 to december and I just kept adding AquaFinesse and chlorine regularly. I tried to fix the problem in december, too late I guess. I followed advice from a spa dealer and what I was able to find on the internet. Among the things I did in december:
    - changed the water 2 times
    - added sodium bicarbonate
    - added Leisure Time's "FoamDown"
    - added "JetClean", let it sink in for the night, tried to wash the surfaces with water and vacuumed any remaining water as best as I could. When I refilled the tub I was horrified to see the water was immediately dirty.
    Any advice would be greatly appreciated.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,774
    Re: Persistent water quality problems [VIDEO]
    I don't know what's in jet clean, but my money is on it. Its likely still cleaning your jets...which means another water change may be on tap
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Dec 2014
    Sydney, Australia
    43
    I got a new spa back end of last year, until recently ( and with my previous spa) I had been dumping in all manner of lotions and potions thinking it was something that just had to be done, having just built a pool and seen the success of the TFP Method there, I have dispensed with my spas Nature 2, Spa Shock, Lithium Hypo, Anti Foam, Clarifier and just dump in 4ppm (50ml for me) of Pool Chlorine (12.5%) after each soak, I am attempting to maintain a residual of 2ppm however the ozonator is making that difficult.
    I had 4 x 3 yr old kids in there on Saturday, I hate to think what they did in there, I forgot to sanitise after, but Sunday the water was just disgusting, 250ml of chlorine over 2 days and nothing else except 2x5 hour filtration, water is clear as...
    8M x 4M Inground Concrete, 40k Litres, Waterline Tiles/Quartzon, Viron P320 VS Pump, Sand Filter(Glass Media) Astral VX-9 SWCG, Heatpump w/ Solar Cover. Zodiac V3 4WD Robot. Bullfrog A8D Spa(1800Litres).
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Here is a link that includes another link for cleaning and refilling and caring for your spa.
    http://www.troublefreepool.com/threa...-Spa-(or-pool)
