Thread: Liner has pulled away from corner of pool. Advice?
    Pittsburgh, PA
    15
    The liner has pulled away from the wall in a corner of my inground pool. Is this an easy and relatively inexpensive fix, or is this something that would require breaking up/redoing the cement?
    Also, on a separate note, as you can tell from the photo, I drained the pool (except for a small amount of water in the deep end that frogs have been enjoying). I did this because:
    • I figured it might have to be done to reset the liner
    • The liner has become wrinkled/creased on the bottom of the pool and I wanted to try to smooth it out
    • an abundance of cheap algaecide from summer of 2013 still was foaming the water at times last year
    • the underwater light hasn't worked since I bought this house 5 years ago and in case it's the bulb, I figured to tackle this at the same time
    Anyway, I'm primarily asking about how to repair the liner where it was pulled from the wall, but if anyone has advice about the wrinkles/creases, I'm all ears.
    Thanks.
    * Bought a home 2010 with a vinyl IG, believed to be 8,800 gallon
    * Hayward 3025 Swimclear filter, with Hayward 1.5HP Super Pump ... 50.76 GPM
    * TF100 testkit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Liner has pulled away from corner of pool. Advice?
    Perhaps you'll find some help info in here: Liner out of track ABCs
    Essential Links:
