Results 1 to 13 of 13
Thread: Suction side, replacing all valves
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Here's a quick shot of what I'm working with. Putting in 2 3-way Jandy Neverlube valves to replace the 3 cheapo 2-way valves, main drain valve did not hold air lock when closing last fall so it was chopped, plugged.
    Sent from mobile device. Beware of brevity and spelling errors!
    Isolated Spa - 345 Gallons
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Suction side, replacing all valves
    Good move, those will always fail at some point.
    Essential Links:
    Feb 2014
    Central Minnesota
    5,080
    I still hate that the underground runs are flexible PVC but until they're a problem, not going to replace them. The only complication I have is that the MD run already has a union (hard to see, but below the plugged pipe, you can just see the union down lower) and there's not going to be much left above ground once I chop it off again and splice in the new rigid PVC set up. The other issue is I don't have a lot of area to work with so I'm using the side of the 2 3 way valves as the inlet, rather than the center. Going to shave the lever tab stop off the valve that will control flow from the skimmers so that I can still run either skimmer by itself as needed. Even when your rotate the top plate to make the side of the T the "Inlet" the tab prevents rotating to be able to isolate either skimmer independently.
    It is much better to rotate the three way valve so that the center port is the outlet and the two side ports are the inlets.
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by JasonLion View Post
    Sorta confused by terminology. Since I am on the suction side, each three way will have 2 inlets (water flowing into valve) and 1 outlet (water flowing out of valve). The default configuration is as pictured:
    My plan was to have, starting at the pump the valve (#1) as pictured with the opening on the right connected to the pump, the opening in the center going to the main drain and the opening on the left going to the other 3 way valve (#2) for the skimmers. Then to have valve #2 rotated 180 degrees, similar to as pictured with the opening on the right going to valve #1, opening in the center going to skimmer A and opening on left going to skimmer B:
    Not sure in these cases which direction the INLET label on the top of the valve should be oriented to.
    The middle-port, port #2 in your description and the port closest to the middle in the first photo should be the one connected to the pump (or connected to the other valve on the second valve).
    When used on the suction side of the pool, the two ports that are directly opposite each other should be the two inlet ports. And the port that has nothing opposite it should be the outlet.
    Feb 2014
    Central Minnesota
    5,080
    Was hoping to orient them differently in the interest of saving space, neatness and less quantity of 90s I'd have to install. I'll have to play with some layouts, maybe shifting one of the flexible skimmer suction lines coming out of the ground.
    Feb 2014
    Central Minnesota
    5,080
    Part way done. Looks fairly good so far.
    Still have to squeeze the other 3-way in but the flex PVC should make it pretty easy.
    Feb 2014
    Central Minnesota
    5,080
    It's done. Would have liked to make it more spacious but space was limited.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    looks great!
    Feb 2014
    Central Minnesota
    5,080
    Filled to level where I'm able to run the pump. Lost no volume over night. Ran the pump with new suction side plumbing with no air bubbles in pump basket after achieving pump prime. I believe victory is mine!
    DFW, TX
    24,516
    Congrats on a job well done!
