Results 1 to 8 of 8
Thread: Ratchet straps instead of rope - Intex
    My rope for my intex frame pool is pretty much useless now, I've read on here about ratchet straps, just wondering if anyone could provide me with any information or pictures of how theyve done it? Also how long will the ratchet strap need to be for a 15ft pool?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Ratchet straps instead of rope - Intex
    I'm not sure how they've done it, but you'll need about 48-50' for that pool to have plenty to work with. You could supplement some straps with really strong Nylon rope most likely. Good luck on it!
    Essential Links:
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Might I also suggest a boat winch strap for length if you can put a ratchet thingy on it.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    That's a better suggestion Woody.
    Essential Links:
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    This is exactly what I did with ours although it's an 18ft pool. The rope wasn't cutting it so I used 5 ratcheting straps around the bottom.
    They've been on this pool for 6yrs and have done the job perfectly at keeping the legs where they need to be. It's easy enough to go around and tighten them if needed but after the first year I never touched them again.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    My rope is pretty much disintegrated and I'm not even sure where it is...it's sort of buried under the dirt that erodes around the pool. I uncovered some of it when I was finally adding a border around my pool last weekend...
    I'm a bad pool owner.
    lol
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    May 2015
    Houston
    8
    Thanks for the info. What is the width of the strap you used. I could only find 1 inch thick straps and the 2 inch straps were pretty heavy so wanted to be sure if they would work.
    Quote Originally Posted by Jamison04 View Post
    May 2012
    Las Vegas, NV
    92
    Intex 22' x 52" Ultra Frame - approx 10,000 gallons of water
    Intex Sand Filter pump (8hrs Run Time)
    Krystal Clear Saltwater Model 7110/8110 (6hr run time/day)
    K-2006 TEST KIT
