Thread: ozone purification
    rajung's Avatar
    Mar 2015
    Iowa
    185
    ozone purification
    My pool is just under 3 years old,was using biogaurd silk sticks,now for the last 12 months using nothing but bleach or other grocery store products.
    This year I wired in a timer so the pump runs 10am - 6pm
    During brushing the pool tonight I just realized my ozone purification system as doughboy calls it, was still running since its plugged in directly to outlet.
    I check my FC and ph daily-Was I upsold on this thing while being new?
    Never had algea but then never let the pool go a day without adjustment off adding chlorine or borax
    current test
    PH 7.4
    TA 110
    CYA 40
    FC 4.5
    CC 0
    our pool doesn't get used a lot, maybe once a week by a couple kids and daily by me, but just floating around like a leaf.
    Starting to think I was sold something that just runs 24/7 and buzzez, and if this thing does run all the time does it do any damage with no water flow when pump is off,just has a long hose from it connected to a ventury typ PVC threaded tube.Thanks
    Doughboy AG 16' x 32' oval, 13,700 gal.
    AquaView by Doughboy 150lb sand filter model 0-1709-20
    PowerLine pump by Doughboy model 0-3047-200, 1.5hp-single speed-20amp
    Gulfstream electric heater-HE125-R-A
    Taylor K-2006 test kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: ozone purification
    Support the site
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi,
    as long as you keep your chlorine to the proper level, then you dont need the ozone. So, probably, yeah, you were upsold. Dont feel bad though, a LOT of people are suppled that and more, just becuase they dont know wny better.
    Your test numbers look great! Nice job on that.
    Divin Dave,
