Results 1 to 15 of 15
Thread: Round pressure gauge vs. square back
    May 2013
    North East Ohio
    959
    Hopefully this makes sense...
    My Waterco pump has a "rounded indentation" for a gauge and a o-ring.
    All the gauges I find have SQUARE ends and when I tighten it the o-ring does not seat. This has leaked since day one and I would like to fix.
    Any ideas where I can find a rounded back end to fit my round opening ?
    Hopefully this picture will help.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Round pressure gauge vs. square back
    The square sides are so you can put a wrench on it. You shouldn't need an o-ring, just some Teflon tape on the threads. Was it not super hard to get the gauge to go in that far? Mine wouldn't go that far without a wrench most of the way.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    May 2013
    North East Ohio
    959
    Quote Originally Posted by n240sxguy View Post
    Mmmmm, I got a ton of Teflon (like 5-6 wraps) and I tightened by hand. Wonder if I have a different issue than I thought ?
    30,421
    Too much Teflon (2-3 turns is enough) and too many turns on the gauge.......it looks like it has bottomed out......maybe stripped.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,013
    I'm wondering if that pump might have some oddball metric thread that's close, but not the same, as national pipe thread. I looked up the waterco website and looked at some manuals to see if it had a parts list, and it's in a bunch of languages. And no parts list.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Gotta be something going on. Mine is 1/4"npt. I always use 5-6 turns of Teflon. Mine tightened up in 3-4 turns max. Npt is cut on a taper, so it should take incredible force to get it in that far.
    May 2013
    North East Ohio
    959
    Yeah by all means I did not use incredible force I gotta believe it's some bizarre size.... I'm sure I can call Waterco and see what they say on the matter
    22,550
    It's most likely BSP parallel threads which require an o-ring. It would be close enough in size to a NPT tapered thread that it would fit, but it wouldn't seal.
    May 2013
    North East Ohio
    959
    Okay if that's the case what do I do
    22,550
    Grainger has them and I'm sure other places do as well.
    Is it 1/4 or 1/8? 1/4 will actually be 1/2" OD and 1/8 will be 3/8" OD.
    Also what size is the case? 40 or 50mm (1½" or 2")
    They also make adapters from BSP to NPT.
    May 2013
    North East Ohio
    959
    Just to close the loop on this, I contact the MFG and they shared it is BSP thread. Since they are international, they have this "issue" to deal with.
    Now I just gotta find one of these suckers....
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    See if you can find a bsp to npt bushing, then you can buy the same type of gauge the other 90% of us use.
    May 2013
    North East Ohio
    959
    Ok, so is this what I need ?
    http://amzn.com/B004RCOY5O
    The sizing looks wonky, but I am always confused on thread sizes. What I have now is a standard gauge, just like what is sold on TFP...and it FITS (well sort of)
    So I have a 1/4" NPT male, so that means what I have above is wrong...and I need a 1/4 BSPT - 1/4 NPT, but low and behold I can't find one of those
    22,550
    Here's one. It's a little expensive, but it's stainless steel.
    Searching for 1/4 female npt to 1/4 male bspp should turn up more.
    Here's a cheaper one from Zoro.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by Bama Rambler View Post
    I'd take the one from zoro. Jeez $24 for a stainless one!
