Thread: Aquabug doesn't work
    jmcdtucson's Avatar
    Jun 2014
    317
    I bought an aquabug for my AGP off Amazon. It worked once, long enough for me to recycle the box. Now it just heads to the nearest corner and sits there and will never get out of it.
    I've looked at the unit and read and read on this site. Flappers appear to flap. Shoes appear to jiggle.
    It seemed to work the first time. It would go into the corner then eventually turn around. The 2nd time and every other time it doesn't work.
    In troubleshooting, I noticed pump pressure was low - about 5 psi. After reading a lot and thinking low pressure might be the issue, I cleared my outflow strainer - which was partly clogged. Now the pump runs at 10psi again like it always has. It drops to about 8 psi when the aquabug is hooked up.
    There is a very small air leak somewhere in the aguabug's hose but only enough to produce a stray bubble or two either in the pump basket (when I don't run with the leaf canister) or in the Hayward leaf canister if I have that hooked. I've tried with and without the canister. If the canister is there, air very slowly accumulates in the canister but there is none in my pump basket. So I don't have a suction-side leak in my pump plumbing. I've tried to find the leak with no success but, again, it's very little.
    Should I just return it to amazon or is Hayward good to deal with? This is so frustrating - I just want something that will vacuum the pool
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    DaneCE's Avatar
    Jul 2011
    VA
    279
    Re: Aquabug doesn't work
    If you do return it, the Baracuda W01698 Ranger is a good low cost option found on Amazon.
    jmcdtucson's Avatar
    Jun 2014
    317
    Well, I've returned the Aquabug.
    I looked at the Batacude W01698 but it says "(not recommended for Intex/soft-sided pools)"
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
