Thread: How many LED lights and where should we put them?
    Dec 2014
    Tallahassee, FL
    5
    Trying to figure out if our size pool (16x34...really 16x29 when you remove the sunshelf area) will need 1 or 2 LED lights? Any suggestions on where we should put them? Attached is the pool layout I made in paint (so it is definitely not to scale!). We want to avoid putting the light(s) on the wall in the deep end since that will face the house.
    We are also debating doing LED bubblers...any thoughts on those? Or would maybe a smaller step light work for the sunshelf? Or should we not even worry about lighting the sunshelf? Thanks for the help!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Re: How many LED lights and where should we put them?
    If you want your pool really lit up, then I would recommend 2. But I would put them on a long wall. 1/3 distance from each end. I thing that would spread the light about as evenly as you can. Lights Facing away from the house/ gathering area.
    If you did that, then the one nearest the sunshelf would light it and the steps up a bit too.
    If you put one each side of the steps, the there will be a big difference in brightness between the shallow and deep end. Especially with the longer color wavelengths, like red and purple.
    Divin Dave,
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    I think Divin Dave gave you the perfect recommendation. Two for sure and along a long wall. I would put them on the wall that faces away from your sitting area outside if possible.
    43 x 19 Gunite Pool w/ spa and fire pit, 19,000 gallons, Pebble Sheen Aqua Blue finish, Jandy 2 HP VS E-pump, Jandy 580 sq ft Cartridge Filter, Jandy LXI 400k Heater, Jandy Aquapure 1400 SWCG, 4 Jandy LED color lights, Aqualink PDA and Iaqualink, Polaris 280 with Booster Pump. Polaris 9550 Robot Cleaner. 1 HP Silencer Air Blower for Spa http://www.troublefreepool.com/threa...NAL-INSPECTION
    38,235
    I think on the long walls makes sense ... I might consider putting them on opposite walls as it could give better coverage.
