Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Vacuum Pool, Dirt returns within a couple hours????
    Apr 2015
    key west, FL
    9
    I have a Summer Escapes 14' x 42" with the skimmer attached to an Intex 2500gph pump with paper filter.
    I vacuum the pool and a few hours later it looks like I haven't done anything. The dirt is very fine and I'm going real slow, no trees above pool just clear sky. The water testing is right and water is clear.
    Any Ideas?????
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,542
    Re: Vacuum Pool, Dirt returns within a couple hours????
    You could mix up some diatomaceous earth and pour it into your skimmer and it will help your filter to filter out smaller particles by effectively clogging it up a bit. Only add a little at a time, as too much can reduce the flow. Although you've got plenty of pump for your size pool. I got some at Ace Hardware. Any pool store should care it too.
    A better filter cartridge might help as well. I know some people here are recommending some alternatives to the Intex filters Sorry, but I don't recall the brand. I have a sand filter myself.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Mar 2015
    Baton Rouge, Louisiana
    19
    I know when I when I'm vacuuming my pool by hand I cant go to fast. If I do the dirt just moves around in the water and doesn't get sucked up. A few hours later it settles on the bottom again.
    44,000 gallon IG vinyl liner pool. 1.5 hp single speed motor on E Z flow pump/sand filter. Unknown age of pool, Kreepy krauly vacuum, Taylor K-2006 Test Kit.
    38,359
    Welcome to TFP!!!
    The Intex cartridge filters leave a lot to be desired. One upgrade would be getting a Filbur/Pleatco/Unicel cartridge instead of the Intex disposable ones. See: http://www.troublefreepool.com/threa...A-filter-again
    A better upgrade would be getting one of the sand filters.
    I do not think adding DE to your Intex cartridge is recommended.
    Originally Posted by PhilGillis
    First time pool owner. Have a 16x48" intex ultra frame, 1500 gph pump/A filter, and saltwater setup. Kept getting sediment collected on the bottom the pool. Stir it but it would just go through the hand skimmer. Was about to order a sand filter with bigger pump so I could vacuum also as my setup didnt come with filter vac and didn't think my 1500 pump would do it well. Anyway, put a white athletic sock over the return and just stirred up the pool getting the particles in the water versus on the pool bottom. The sock has totally removed all of the grit as I guess it was just going straight through the filter. I do keep filter clean and all that . . But just something as simple and cheap as a sock has the pool absolutely clean and hasn't interfered with chlorine production or any ill effect. Got the tip about the sock here . .so just wanted to say thanks. I still may upgrade to sand . . But it won't be to water/grit conditions. Unbelievable.
    Phil
    This helped me years ago, give it a try!
    18x52 Ultra Frame with 1600 gph sand filter and intex skimmer
    Apr 2015
    key west, FL
    9
    I'll try the sock method first since I have a drawer full
    Thanks everyone......
    Get a Unicel. Difference is night and day. I posted some pics of my Intex cart and the the Unicel after running a week. Intex was still white, Unicel was brown and full of dirt. Unicel is about $15 at Amazon and will last up to 5 years if cleaned properly.
    1) 7500 Gallon Free Form Gunite Pool / 800 Gallon Gunite Spa
    2) EasyTouch 8 Automation / IC20 Intellichlor
    3) Intelliflo VS Pump for pool and water features - Cartridge and DE Filter / 2 Speed Pentair Pump for Spa and Cartridge Filter
    Apr 2015
    key west, FL
    9
    Update,
    I tried the sock "didn't Work"...........Unicel filter "didn't work".............vacuumed real slow "didn't work".........left the vacuum hooked up so that intake was from bottom of the pool "didn't work"........
    Ordered a 5 micron sock that I will try...
    Any other suggestions?
    Thanks again
    38,359
    Are we sure there is not a chemistry problem and not that it is passing through the filter?
    Z7What's Avatar
    Mar 2015
    New Orleans Area
    141
    Are you sure its dirt?
    Wayne
    24'X54" Round 15,000 Gallon Pool
    Pentair SD-60 Sand Filter With 1.5HP Pump & Center Floor Drain
    Lil' Shark Vacuum With Leaf Canister
    New TFPC User And Couldn't Be Happier
    Pool School + Test Kit + Pool Math = A Perfect Trouble Free Pool
    Apr 2015
    key west, FL
    9
    It is real fine dirt and checking the water with the AquaChem strips the chemistry is right on. The bio-filter 5 micro sock will be delivered middle of the week. Going to put it on the discharge and try to filter the water.
    14' x 42" 3300 gallon Summer Escape AG pool, Intex 2500 gph pump with Unicel cartridge, Taylor K-2006 with FAS-DPD
    38,359
    Test strips are worthless that that does not tell us anything. If you truly want to take control of your pool then you need to invest in one of the Recommended Test Kits.
    Dirt is gritty, can you feel it?
    I am almost willing to bet that your FC level is too low for your CYA level and what you are seeing is actually algae.
    Apr 2014
    FOUR cORNERS
    111
    I had this problem also, could never ever get the dirt off bottom, it use to take me 3-4 hours, (with cartridge) and just go super freaking slow. Well that all changed when we upgraded to a sand filter, new learning curve but the difference is night and day. pool has never been cleaner, and only takes about 30-50 minutes, every 7 days. I am so happy we upgraded
    16 'x 48" Metal Frame Intex 5065 gallons, 14 Inch sand filter,Hayward Skimmer SP1091LX Dynaskim, Test Kit TF-100
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Just say no to strips.
    Drops or nothing.
    Isolated Spa - 345 Gallons
    Apr 2015
    key west, FL
    9
    Used a pump trap after the pump with a 5 micron filter in the basket, no more fine dirt.
    here is what I have done so far.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    hey, that looks like a party! Key West, too. woohoo!
    Switching to a sand filter is really the way to go. I can tell you that I am super anal about dirt in the pool and would drive myself absolutely crazy trying to keep it clean. The other thing that really helped was adding some water clarifier which helps all the tiny particles clump together so they can be vacuumed. I still get sediment on the pool floor but my pool is under two really annoying trees. I also notice an increase in sediment after the pool has been shocked, but once I vacuum (which I do about every other day) it disappears.
    20x45 in-ground 42k pool and spa built in 1989. Just moved into this home and am still in the learning phase of understanding equipment
    38,359
    I think you put a band-aid on it and your chemistry is likely not correct.
    You ditch the strips and get a real test kit yet?
    Casey's Avatar
    SW PA
    10,450
    Quote Originally Posted by JenniferW View Post
    With TFPC, there is no reason to use clarifier. The only time a SLAM occurs is if there is presence of CC or the water turns due to forgetting to add chlorine.
  20. Back To Top    #20
    Apr 2015
    key west, FL
    9
    Ok, I have the Taylor kit and slammed the pool, here are my numbers CYA 40, FC 8, CC .5, PH 7.6, TA 70, CH 90. I did the overnight test and it lost 1.5 of FC and CC went to zero. Is 1.5 lost too much overnight? Should I slamm for a little longer?
    Thanks for all the help
