Results 1 to 8 of 8
Thread: Small Outlet filter????
    May 2014
    by that Big Arch
    26
    any ideas?..I am thinking it might prevent some final junk from entering pool..cartridge type I can easily swap
    -1.5" pipe
    -1hp pump
    -sand filter
    thank you- god speed
    38,508
    Re: Small Outlet filter????
    I have no idea what you are asking
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    +1
    May 2014
    by that Big Arch
    26
    No biggie..had an emergency call so I had to leave what I was writing in a hurry (my bad)..what I have in mind is putting an additional pump filter between the pump/filter outlet and the inlet into the pool eye..does that help?.any issue with this..again my bad
    38,508
    There should be no point in doing that. It would just add head loss and lower your flow rate.
    Nothing should be making it past your filter unless you have a problem in it.
    Please add your pool details to your signature as described HERE as it will help us help you.
    May 2014
    by that Big Arch
    26
    thanks for the help
    22,553
    I actually thought about doing that to polish the water. I never got around to it because of the cost to benefit ratio. I was thinking about a 1 or 2 micron filter after the main filter, but by the time you got one large enough to keep the pressure drop low enough that it doesn't affect the flow, it gets pretty expensive.
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    What is passing through your filter? If it is larger debris, you might have channeling in the sand. Have you back washed recently? If so, what is the PSI before and after the backwash?
    TF-100 | 13.6k gal (24' Round) AG | Chlorine | Sand Filter | Two Speed Motor | Installed June 2014 | Last Opened April 24 2016
