Thread: Aquarite cell size question
    Mar 2015
    Saint Johns, Fl
    6
    Is the control unit for the AQR9 and AQR15 the same? Or are they sized (power supply) for the cell that comes bundled with them? The main reason I am asking is I wanted to get an AQR9 (which should be fine for our pool), but wanted to know if I could upgrade to the T15 cell later, if I needed/wanted to (without having to replace the entire unit). I did notice that they sold the controller as a standalone, noting that the cell was sold separately, but was not sure if that translated to a single controller across their bundles.
    TIA
    - Tom
    13k pool, recently refinished w/ Marquis, planning to convert to salt.
    38,284
    Re: Aquarite cell size question
    The newer controllers like sold in the last 5+ years can handle any size cell.
    There is a setting to select the cell size.
    Mar 2015
    Saint Johns, Fl
    6
    Thank you very much for the fast response. That was what I had suspected, I truly appreciate the confirmation.
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Why not just get the 15 now? It shouldn't have to work as hard and in theory should therefore last longer.
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    I would go with the T-15 now. The cell will last longer. Also, you would need a longer pump run time with the smaller cell to get the same amount of chlorine at the same percentage.
    Support the site
