Results 1 to 16 of 16
Thread: Unsure of time for SLAM
    Apr 2015
    Round Rock, TX
    25
    I started SLAMing last Thursday. I had readings of
    CYA - 45, which seems reasonable as I brought it down from 60 with a partial drain
    PH - 7.5
    With yellowish water( no real algae growth, just leaves/pollen)
    I've been maintaining FC around 18 for the past 6 days.
    First night FC dropped from 26.5(which was probably high due to only waiting 30 mins after adding 5+ just of bleach) down to 10
    Second night, dropped from 18 down to 13.5
    Third night dropped from unknown(wasn't around from afternoon on) to 13
    Fourth night dropped from 18 down to 17
    Fifth night dropped from 18 down to 17.5
    Sixth night dropped from 18.5 down to 14
    The water hasn't cleared much at all over that time. It feels with last night that the process has gone backwards, i.e. larger chlorine loss overnight.
    The pressure hasn't changed much on my cartridge filter over the process, as I had just cleaned it and there isn't much, if any debris in the pool.
    Should I clean out the cartridges on my filter again? Should I just wait a few more days? Any help would be appreciated!
    12,350 gallon IG plaster pool
    Hayward cartridge Swimclear 4025 filter
    Hayward Super II 2.5 Hp pump
    Re: Unsure of time for SLAM
    Welcome to TFP!
    You should see some improvement in the water's appearance, even if very slight. As long as you do, keep up as you have been going. However, if the water doesn't improve at all from day to day then it is time to look into possible problems with the filter.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Welcome
    Are you adding chlorine once a day or more?
    Are you brushing at least once a day?
    Any light fixtures or hidden areas around ladders that could be hiding something?
    Support the site
    Apr 2015
    Round Rock, TX
    25
    I've been adding chlorine approx three times a day, morning, afternoon, and night.
    I've been brushing every time I add chlorine, but given the yellow water, it's hard to see if I get it all.
    I decided to go ahead and clean the filter, and it was fairly dirty. I'm now filtering just the hottub to see if that water clears up. That usually only takes an hour or so when I clean the filter. If that looks clearer, I'll set it back to full pool and give it another couple of days.
    It's very hard to judge in this area, because there is tons of pollen in the air, and every rain brings all of it into my pool.
    Apr 2015
    Round Rock, TX
    25
    FC went from 19 yesterday at 5:00, to 12.5 this morning.
    Added chlorine to move it back up to 18.
    Should I assume my CYA level is higher than I think? Keep the FC higher for a few days? It looks like something in the pool keeps using the chlorine up every night, but not dying.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum mmedulan
    Are you testing the CYA yourself, outside ?? What kit are you using ??
    If you have a light and ladder those are two good areas to check as are the back of the skimmer weir doors and inside the skimmers for anything green.
    Solar Blanket, Well Water, Borax Added. 68
    Mod Squad pooldv's Avatar
    DFW, TX
    24,460
    With CYA of 45 you should be keeping FC at 18-20. That chlorine is being consumed is good and that is the goal. Stuff is definitely being killed if chlorine is being consumed. That is how it is supposed to work. Keep rolling.
    Apr 2015
    Round Rock, TX
    25
    I'm testing the CYA myself with the TFT100 kit. I've already gone through the entire chlorine powder with a week of SLAM, so I'll probably run out before the refill order gets to me. Then I guess I'll have to keep adding blindly for a few days.
    Apr 2015
    Round Rock, TX
    25
    I think when I checked this afternoon, I'm finally starting to see a difference. The bottom can be made out just a bit clearer I think. Of course we're supposed to get a bunch of storms in the next couple of days which will kill us with pollen again!
    I'm going to keep the FC a little higher, around 20, to try and kill everything that falls in there.
    Apr 2015
    Round Rock, TX
    25
    Starting to actually clear up now. I can see any little debris on the floor as I clean it up. I think raising the FC to 20+ has helped in the last day and a half. Hopefully I'll be swimming early next week!
    Thanks!
    -M
    DFW, TX
    24,460
    Alright! That is good news!
    Apr 2015
    Knoxville, TN
    64
    Just wanted to say you aren't alone. I've been slamming for 17 days and still have something eating up the FC.
    Sand filter
    Salt Generator
    25000 gallon IG Vinyl
    Apr 2015
    Round Rock, TX
    25
    I think that if it's not cleaning up in the first 5 days, that a bump of a couple of FC points is probably a good idea. My water is now a shade of blueish green, rather than greenish yellow.
    Hopefully should be sparkling in a few days!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I would agree, it's what I would do and not letting it drop below shock/SLAM level is vital. Doing so causes it to drag and drag.
    Essential Links:
    Apr 2015
    Round Rock, TX
    25
    I'm thinking that I am finished with the SLAM process. The water is clear, and I've passed the OCLT and CC tests.
    I'm going to bring down the chlorine over the next few days, as well as limit the filter time.
    Thanks for the support!
    -M
    DFW, TX
    24,460
    Woohoo!! Another TFPC success story! Congrats.
