Thread: Filter guage stuck
    Apr 2015
    Suffolk, VA
    11
    Filter guage stuck
    The guage on the sand filter has the needle stuck behind the stop pin. I don't know how this happened, I assume during the winter. Do I just replace the guage?
    Vicki
    33x18 Oval shaped AG pool, about 12,000ish gal
    1.5 Hayward Power-Flo LX pump
    Dream Line high rate sand filter
    Also 375 gal Baja 7 person spa w/cartridge filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Re: Filter guage stuck
    Yep. Odds are, the insides froze and it went all the way around to end up behind the stop. It's ruined. Replace it. http://tftestkits.net/Untitled-Category-c12/ has good ones. If you need any test refills, order them at the same time and save shipping.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    That's exactly what happened to mine. Take it apart and see how they work. You'll be amazed, and completely understand what happened to it.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Apr 2015
    Suffolk, VA
    11
    I assume it's okay to continue to use until I get the new guage put on? I just won't be able to read pressure?
    Vicki
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Correct you can run it but won't know the pressure. Get it fixed sooner is better.
