Results 1 to 9 of 9
Thread: My AGP & deck project
    Jul 2008
    Solon, Iowa
    170
    Not sure if this is the right place, here are pix of this summer's project (still underway).
    Last fall I tore down a screened-in porch and a lower deck that spanned the space between the house and garage. Lot's of pressure treated lumber for me to re-use for the pool deck. Here's a picture after the spring dirt work, to bring the top of the pool just under the planned deck height.
    This spring we removed a lot of dirt, and planned for drainage away from the pool, consistent with the natural slope of the lot, through the spruce trees. We also broke a sewer line that revealed itself on Memorial Day, of course. Then our part of Iowa suffered biblical flooding and nothing more happened until well into June.
    My wife and I decided that we'd let a PB do the install, and I'd tackle the retaining walls and deck. The pool deck will completely surround the pool, and join with the remaining lower deck, which connects via stairway to the upper deck off the kitchen. My crew: me. To wife.."don't worry, I'll have this knocked out by the end of July. By August it'll be pool-party time" Not.
    Pool and kids are in (and 68 degree water). No retaining walls. Never-ending rains.
    Retaining walls in (last time I moved railroad ties they were lighter), 19 footings (42 inch deep) dug and poured by hand, posts and beams nearly done. My teenaged sons were helpful, sort of.
    Joists almost done. Since we have a beaded liner, I decided that I wanted the deck to hide the top rail. I'll be cutting joists if I need to remove the top rail, but I planned the beams so that the joists can be sistered/bolted back together.
    Here's where I'm at today. Solid vinyl decking (priced like solid gold). Filter and pump are under the corner of the deck where the screened porch used to be. Still need to cut access to the skimmer. Filter pump access will be from under the deck. Aquatrol panel will be mounted above the deck.
    Now about time to close the pool. Hope to finish the decking, install rails, steps and gate, and patch up the siding before the snow flies. Final pix then.
    Kelly
    15X30 AGP, Lomart beaded liner;
    1.5 HP Sta-Rite pump with 21 inch sand filter (Zeobrite media)
    Mineral Springs (Aquatrol) SWCG, Rigid PVC plumbing, 2 inch
    Four 4X12 Techno-Solis solar panels, rack mounted, Goldline Solar Controller
    Casey's Avatar
    SW PA
    10,444
    Re: My AGP & deck project
    The pool and decking look FAB but I have one question...
    How are you going to cover it?
    Are you going to somehow anchor the cover it to the deck?
    The reason I ask is because my pool cover tightens around the pool with a cable thingy-mabobber.. what is that called... a winch type deal...
    So, I'm just curious.
    New Brunswick Canada
    819
    Great Job, I know, I did my own deck for my inground pool, up in the cold north, no one could guarantee against cement cracking.
    I wouldnt cover it at all in the winter, we leave ours open, let her freeze up like a rock, and there are no worries come spring, both neighbors have covers, and they are always complaining about having to take them off in the spring.
    Again, great job!
    Jul 2008
    Solon, Iowa
    170
    I can get under the deck - the area between the retaining walls and pool makes a little walkway (for a duck-waddle that is). I've left just enough room for the cover to slip under the joists. Should work.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Nice deck! My question is IF or SHOULD you need to tend to your liner have you left enough room to get the rails and caps off?
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Butterfly's Avatar
    South Carolina
    10,045
    What a great job! That solid vinyl decking looks fab!
    We'll be waiting for the final pix......before the snow flies! 8)
    You're done SLAMing when:
    Jul 2008
    Solon, Iowa
    170
    TizMe,
    I have a beaded liner, so as I understand it I can change the liner without removing the caps and rails (tell me I'm not wrong!). The PB said there should be no reason for me to remove the rails except for wanting to hang an accessory over the pool wall (I won't) or for a serious structural failure (I hope not! and the PB set the side supports in cement footings, not just resting on blocks). The bead channel that hangs over the wall is metal with a vinyl skirt, so it should last. But, if needed, I could pull decking up to get to the joists where they pass over a beam, cut the joists, and reassemble. A PITA, but nothing is impossible if you have a reciprocating saw, more lumber, and lot's of patience!
    Kelly
    30,421
    Hi, Kelly,
    As an avid DIYer, you have done a very, very nice job on that deck.
    I see lot's of details in the framing and decking that you wouldn't get if you paid someone to do it.....Nice work!!
    Jul 2008
    Solon, Iowa
    170
    Thanks Dave. That means a lot to me. I lucked out by having a father who taught us that we could do anything if you took the time to learn about it first, and then just jump in and use good sense to solve the problems that pop up.
    Kelly
