Results 1 to 15 of 15
Thread: leveling ultra frame pool on patio
    Apr 2015
    Belgium
    6
    Hi
    My name is Gwen (34 - male) from Belgium (europe)
    I have a question regarding leveling my patio to install my ultra frame intex pool. (2mx4m)Intex 13ft 1" X 6ft 6" X 39"
    I'm currently in a rental house with a big patio.Last year i had an easy set 366cm.This began to roll over at the end of summer.
    what can i do to level my patio (not permanently)?
    thank you very much for any advice
    30,426
    Re: leveling ultra frame pool on patio
    Welcome to the forum. Gravel about 1/4" in diameter works in most situations. How far out of level are you?
    Apr 2015
    Belgium
    6
    2 inches over 13 feet
    6cm drop over 4 meters
    i'm thinking maybe a kind of wooden platform to make up for the difference in heigth?
    Casey's Avatar
    SW PA
    10,450
    You could probably, safely use sand on that side.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I heard of one user that used paper to level his patio for an EasySet (bag) pool. I believe he used old newsprint on top of tarp. I don't know how well it will work for a pool of that size as it has legs.
    A wood deck would need to be engineered/designed for the weight of the pool (6836 kg or 15,000 pounds, plus swimmers) and it would need to not sag, or rot.
    -- Guy --
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I think a simple sandbox would work...2x4 lumber (or the equivalent size in Belgium) would be high enough. Just make a rectangle a little bit larger than the pool, then level the sand or gravel inside that box.
    Jun 2012
    MA
    347
    I would use a few sheets of plywood and some sand
    Apr 2015
    Belgium
    6
    thank you very much for the advice guys
    i'm going for the sandbox...
    i'll posts some pics when it's finished
    MrsDimples's Avatar
    Jun 2014
    England
    47
    I nearly went for that pool.
    Please post lots of pics
    Intex 10ft Metal Frame - 1,185 gallons
    Intex 530 gall. per hour Filter Pump (Model No. 58604) - Cartridge
    Chlorine / pH dip sticks
    Intex 3kw Heater
    Jul 2014
    Oakbank, Canada
    389
    In regards to leveling the deck like you asked, just shim under the deck posts as required with blocks of wood. Lift the deck up with a small hydraulic jack where required, and place shim either under the post, or between the deck and the post. You will have to use thinner shims closer to the end of the deck from where the lowest end is as you go along to the higher end. Actually fairly simple to do. Just place level on deck, lift until level and you can see the shim thickness you require for all the posts required.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Apr 2015
    Belgium
    6
    2000 pounds of sand and i need a little more
    The Wooden box is level with a sort of garden cloth that can let water through ) inside filled with sand so it's easy to level.
    This weekend of next week i will install pool
    Apr 2015
    Belgium
    6
    here it is
    May 2014
    Owen Sound, ON
    44
    That sure looks nice! Good job!
    PJ
    Intex 24'x12'x52" Ultra Frame (2014), 8400 gallons (31800 litres), Intex sand filter and pump, AquaBot Pura4xi, solar blanket, 32' x 10' deck across one side, 4' decks up short sides, better ladder. Proud owner of Hydropool Serenity 5 Hot Tub! Taylor K-2006 Test Kit.
    Apr 2015
    Belgium
    6
    Thx!
    I'm using a Sandpro 20ES (here sold under the "Oceanblue" brandname)
    with integrated
    and uv filtration
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Nice work!
