Thread: Pool Quote - Thoughts & Opinions Please!
    Apr 2015
    Mooresville/NC
    4
    I received a pool quote of just over $40,000 in the Charlotte, NC area for the following:
    Pool Size - 15' x 30'
    Shape - Custom Free Form
    Depth - 3'6" - 6' deep
    All permits required by county
    Excavation - dirt to be hauled from property
    Frame - Rebar all #3 steel with 12" bond beam (Transferable Lifetime Warranty)
    Shell - 100% Gunite (Transferable Lifetime Warranty)
    Steps - 1 set of 3 oversized custom steps
    Sun Shelf - tanning ledge with umbrella sleeves (with 2 bubblers)
    Bench 5' x 18" swim out bench
    Main Drains - 2 with anti-vortex covers for child safety
    Skimmers - 1 largemouth cover with removable basket
    Vacuum line - dedicated vacuum line for cleaner
    Returns - 2" plumbing lines with 5 returns (3 in wall, 2 in floor)
    Coping - Flagstone
    Tile - one row 6" frost-proof waterline
    Pump - Jandy 2.0 hp
    Filter - Jandy CV340 Cartridge Filter
    Light 1 Jandy Halogen light (white)
    Freeze control sensor built into system
    Timer - 24 hour auto time clock
    Chemicals - inline chlorinator (Jandy)
    Deck - 400 sq. ft. Broom finished concrete
    Startup - balance all chemicals, free 30 days of full cleanings
    Selected Options: Jandy salt chlorination system
    8' Bond beam raised +12" +18" (faced with stone) with 2' sheer descent
    Jandy LED multi colored pool light
    Jandy 360 Polaris Pool Cleaner
    Warranties:
    Lifetime transferable structural warranty
    Lifetime warranty on pump housing and 3 year motor (Jandy)
    Lifetime filter warranty (Jandy)
    Lifetime valves warranty - leaking, breaking, & pressure loss (Jandy)
    Thank you very, very much!
    38,540
    Re: Pool Quote - Thoughts & Opinions Please!
    - Make sure main drains and skimmers are plumbed separately to the pump with a 3-way valve.
    - Pump might be over-sized, although may be sized due to the sheer descents ... definitely want to upgrade this to a 2-speed pump.
    - Forget the inline chlorinator (can you get a refund applied toward the SWG?)
    - Why is there a white light and a colored light?
    - Mentions a dedicated cleaner suction line, but then includes a pressure side cleaner??? You sure you want a pressure side cleaner and not a suction side or robot? See: http://www.troublefreepool.com/conte...-pool-cleaners
    Apr 2015
    Mooresville/NC
    4
    Thank you for the reply - the multi colored light was in place of the white light as an option - sorry about that.
    38,540
    BTW, 6' depth is kind of an oddity. Too deep to stand (unless you are all very tall ), too shallow to be jumping or diving in.
    Jan 2013
    Friendswood, TX
    320
    Is your wind direction fairly constant? Mine changes a lot and I'm glad I have two skimmers on opposite sides.
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    jojoman's Avatar
    Jun 2014
    Mandeville,La
    185
    Only 1 skimmer? You really need 2. One in the upwind(or south in my case) direction and one down wind(north in my case) direction . Helps keep the stuff falling into pool from building up in one end of the pool or the other . Or i'm i reading it wrong. 1+ to Jblizzle's comments.
    12K gal, custom flipped kidney bean with spillover spa. All Pentair equipment, Whisperflo 1 1/2 HP, 400K BTU heater, Intellichlor IC 40 SWG, CCP-320 Cartridge filters, Kreepy Krauly pool cleaner with bootster pump, QuartzScapes in Aruba Sky blue, LED lights and travertine tiles for decking and stones on rear edge for landscaping. TF-100 test kit w/ SpeedStir
