Thread: Cave in on buried above ground pool.
    Apr 2015
    Saint Amant/Louisiana
    2
    hey guys.
    I recently started draining my pool to change my liner on a buried 27' above ground pool. It was suppose to be dry for a week and a half. Out of nowhere, downpour. walls collapsed. I saw someone mention before that the pool is not ruined, but I would like to get suggestions on the process to fix. Thanks!!
    Matt
    Saint Amant, LA. Above Ground. 27' round 3 ft buried. 1.5 hp cartridge filter.
    Casey's Avatar
    SW PA
    10,457
    Re: Cave in on buried above ground pool.
    Welcome to TFP.
    You're going to have to post pictures so we can assess the damage.
    Apr 2015
    2
    Here are a few. Sorry it's dark. I will try to take some better ones tomorrow.
    38,475
    Yikes. Why do I think you are going to have to un-bury it and try to reshape the side and fill with water before re-burying it?
    Casey's Avatar
    SW PA
    10,457
    Because that's about the only way to fix It.
    Please do post better pics tomorrow.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    605
    When that happened to mine after Katrina, I had to dig it out and fill in the hole. It ended up costing more than putting the pool in. Good luck!
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
