Thread: How long for PH to stabilize
    Mar 2015
    McKinney, TX
    2
    First off, thanks for this site. It has been a life-saver in the first months of pool ownership.
    My plaster was poured on December 1st. I know that I have read on multiple posts that curing plaster can cause the PH to rise, but how long does that process last?
    I have been fighting rising PH since I first started testing (with the TF-100). I have a plastic cup that holds approximately 20 oz, so I usually add 1 of those per day of 8.25% bleach and 1 every other day of Muraiatic acid. I know my TA is low and a higher level would help stabilize, but I don't know that I want to risk raising my PH too much by adding baking soda if I am able to keep the numbers in line and this is just part of the process. If I skip the MA for 3-4 days, the PH goes to 7.8+ pretty consistently.
    So far, I have added 64oz of baking soda (weeks ago) and have another box ready to go, but should I do it? Everything looks great with the pool and I think I have a good daily process, but I'm just looking to make it a little more trouble free and be able to not worry about things when gone for a few days at a time.
    FC-3
    PH 7.5
    TA 60
    CYA 40
    12,500 IG, Pebble, Jandy CL460 Cartridge, filled DEC-2014, Jandy 2.0 hp Var speed, DEL Eclipse Ozonator, 8 ft table rock waterfall
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: How long for PH to stabilize
    You can leave TA at 60 for a while and see how it goes. Increasing TA could contribute even more to PH rise. It takes up to a year for plaster to cure and stop causing PH to rise.
    Also, the more you run waterfalls and bubblers the more you PH will rise also.
    Good first post! Good job on your signature and reading up on pool school! You are doing great!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Welcome!
    My pool was a few years old when I moved in, so I have no idea how long it took mine to settle down.
    According to the article in Pool School:
    No matter what start-up procedure is used, your pool will consume a lot of acid during the first 6-12 months as the plaster finish continues to cure. It is important to test your pH daily and do not let it climb above 7.8. Be sure to continue to brush the pool at least weekly during this period.
    Mar 2015
    McKinney, TX
    2
    Thank you for the feedback. Guess that I won't worry about it too much and keep doing what I am doing. The trips to Home Depot for the 2 pack of acid won't be ending soon.
    DFW, TX
    24,502
    Yes, keep at it. You could switch to Lowes occasionally.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Stock up when you go, you'll be needing to adjust pH for some time most likely. Pool shops sometimes have better prices, and smaller hardware stores usually have it for 7-8 dollars/Gal if you don't feel like the big Box store trek. I dread going the big stores sometimes.
    Essential Links:
