Thread: Water on top of cover
    May 2012
    Ottawa
    13
    First time opening my pool.
    Due to the location of my return jets/lights, I had to lower my water fairly low in the fall. Due to the amount of snow and ice over the winter I have a fair bit of water right now in my pool but above my winter cover.
    Other than the debris I can see in the water, is there a problem with letting this water into the pool? I think it could save me trucking in a load of water. Is it just a bad idea to let this water into the pool? I'm a first timer and I don't want to do anything that will delay my opening or damage anything.
    17,000 gal, IG, vinyl, single speed pump, cartridge filter, built 2014, SWG, natural gas heater, city water fill.
    Jacuzzi hot tub, j-280 model, 400 gal, with Clear ray, chlorine system, well water fill.
    Taylor k-2006 test kit.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Water on top of cover
    Nope, that seems to be the thing to do for you up north pool closers. I have seen that posted in a number threads recently about people moving, pumping or dumping water on the cover into the pool.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,095
    We do this each year. Our fill water is high in Iron so the only way to top off is trucking in fresh water ($$$$) or using the rain to fill it up. It may open somewhat dirty due to this, however it clears up very easy.
