Thread: In floor cleaning run time
    Sep 2014
    North DFW
    161
    We have a fairly new pool, its been finished about 5 months. I am curious how long people run the pump at the higher rate for the in floor cleaning system. My PB scheduled ours to run for 3 hours a day. I would think all we need is for each zone to have rotated the heads a full 360 degrees.
    39' x 18' IG 3.5X4.5X9 34k gallon w/ raised spa, 3 stone scupers
    Jandy 60 SqFt DE, Jandy PDA PS6, Jandy JXi400 heater, Jandy 2.0 EPump w/SVRS
    A&A Manufacturing ICS w/G4 venturi heads
    2 incandescent lights in pool, 1 in spa.
    38,262
    Re: In floor cleaning run time
    Back 8+ years ago when I have a pool with the in-floor system, they told me that I should have them rotate twice a day ... that ends up being a long run time.
    I think the answer is ... long enough that your pool stays clean enough for you
    Sep 2014
    North DFW
    161
    Hmm, I can increase or decrease the time in each zone. I'm sure I can get it running for 2 full rotations in less than 3 hours the PB has it currently running for.
    Yup, but doing so without unnecessary run time!
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    I've been experimenting with mine. PB had it set up for 5 hours a day. I'm down to 1.5 hours and it seems to be staying clean.
    I would reduce my run time even further, but my system is set up with a dedicated pump and a dedicated skimmer. If I don't use the IFCS, then that 2nd skimmer doesn't do anything.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
