Results 1 to 15 of 15
Thread: Need Some Clarification About the SLAM Process
    Jul 2014
    Independence, KY
    231
    I have read the SLAM documents, and I understand the basic mechanics of what is going on. However, I am left with a few open questions about the process.
    1.) As I have a vinyl pool, won't the high levels of FC (Shock FC) begin to bleach out my liner?
    2.) During the SLAM process, you go up to Shock FC. Directions say to check and re-add chlorine, as algae, etc. will consume the chlorine. That makes sense to me. But when the process is done, and the Shock FC level is no longer dropping, what will drop down the FC level back to Target FC down from Shock FC?
    The way I see it, is if you have stabilizer in the pool, is should minimize the sun's decay, and you no longer have algae, etc consuming the FC, I dont see how the FC drops back down to Target level very quickly. Then couple this with my concern #1 above, and I am left a bit confused.
    3.) At What FC level is the pool safe to swim in again?
    Thanks for the help in advance.
    IG W/Vinyl Liner Oval 18x40, 21K gal, Oval 3'-8'
    Pentair Intelliflo VS Pump, Sand Filter
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: Need Some Clarification About the SLAM Process
    Quote Originally Posted by Yev View Post
    1. no, in short, shock/SLAM level FC won't bleach the liner.
    2. the sun - it won't be terribly quick, but it will be quick enough to avoid damage to anything.
    3. below shock level FC is safe to swim in. (assuming all other criteria of the SLAM are met of course)
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    +1 what mrcarcrazy said. exactly.
    Divin Dave,
    Jul 2014
    Independence, KY
    231
    Quote Originally Posted by mrcarcrazy View Post
    My CYA is 50, so according to the table my Shock FC is 20, and my Target FC is 6. So when the SLAM is done, I can swim as soon as FC drops to 19? Are there any problems with swimming at 19 (Bad on suits, hair, skin, eyes, etc)?
    And I'm generally not trying to be difficult, just understand better, but if it is safe to swim at the 19 level, then why not just leave it at 19 always, why allow it to ever drop down to the Target level of 6?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Also, anything organic that gets in. Chlorine is very consumable.
    Even though some protection is given by Cya, some is still lost to the Sun.
    Because keeping the FC at 19 would cost a lot more chlorine. You only need that level to have enough to kill above and beyond the Cya level. Since some FC is tied up by Cya, you have to overcome it with higher FC.
    There is nothing wrong about asking questions, so that isn't being difficult.
    Essential Links:
    Smykowski's Avatar
    Sep 2011
    3,065
    The fact that you're asking the questions you are indicates that you're starting to "get it." Congratulations on becoming a TFP'er!
    Given a CYA of 50, no problems swimming at an FC of 19.
    Since chlorine is constantly being consumed, maintaining it at 19 would get expensive.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    The consumption of chlorine is why we say testing should be done daily, even after the SLAM ends. You need to get a feel for your daily consumption. Remember, daily consumption is a guideline, not a hard and fast number. In the spring you will use less chlorine than the height of the summer. A few rainy overcast days will cut it back. You will begin to get the appetite of your pool for chlorine. Remember, you need to feed it regularly. Folks who test and add chlorine on the weekends end up with green pools.
    And, as to you asking questions - we like answering them - that is why we are here.
    Support the site
    30,421
    The daily chlorine loss, even with CYA, is a percentage of available chlorine (it's not quite that simple, but close enough)
    If you lose say 33% daily and your FC was 6 ppm, you would lose 2 ppm FC
    If your FC was 19 ppm you would lose roughly 6 ppm......triple the amount of FC.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Smykowski View Post
    +1 to that!
    Essential Links:
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    The more questions you ask the fewer mistakes you make and the easier it becomes to understand how everything works.
    You're on your way.
    Solar Blanket, Well Water, Borax Added. 68
    SCon36's Avatar
    Jul 2014
    Bedford, KY
    121
    I fought high CYA levels last year and my family swam in water with higher than usual FC with no issues. Are you guys I NKY close to swimming already? We swam on Derby day in 2012 but have t been close to that date since. I'm just an hour south of you.
    SCon36
    24,000 Gallon IG vinyl pool (16x36x8) with Hayward S200 sand filter and Hayward pump and heat pump. Built August 2011. I use a Taylor K-2005 test kit with a K-1515 add on.
    https://www.youtube.com/watch?v=bIgL...0MyAw&index=29
    Jul 2014
    Independence, KY
    231
    Without a heater, water is just now 61, so only the brave would get in.
    May 2014
    Franklin, NC
    9,184
    getting close. I was in our pool at 70....
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,493
    Yeah, brave, that's what we call em.
