Results 1 to 13 of 13
Thread: Re-Direct Backwash
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    Re-Direct Backwash
    Question 1:
    I would like to change where my backwash goes. Currently I have one of those flat roll-up hoses that I attach and unroll each time I backwash. But the exit port is pointing right towards my house causing the area between the house and pool to get wet. Can I put in a 90 degree turn and use a PVC pipe to send the water through a perforated landscape drainage pipe? I wan't sure how the change in direction would affect the flow rate (if any). I assume that as long as the PVC pipe is the same diameter as the exit port, then that should be fine, right?
    Question 2:
    Anyone ever try to catch the backwash water to use for watering flowerbeds or gardens? I fell bad just wasting all that perfectly good (slightly dirty) water. I wonder if I could store it in a rain barrel (like this one: http://goo.gl/btgZTG).
    Anyone care to share their plumbing setup for backwash?
    TF-100 | 13.6k gal (24' Round) AG | Chlorine | Sand Filter | Two Speed Motor | Installed June 2014 | Last Opened April 24 2016
    22,548
    Re: Re-Direct Backwash
    It's fine to turn the backwash a different direction as long as you use the proper diameter piping and fittings.
    I don't recall anyone 'catching' the backwash water, but I don't think it'd be a problem. Once caught the FC would drop to zero pretty quickly, so it wouldn't hurt any plants.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I have my flex hose (like yours) fitted with a female camloc on the end and a male on the outlet. With the flex hose, I move it wherever I want to water trees/lawn. I can snap a pic of this sometime. It never leaks or sprays out anywhere, very easy to connect and remove with no troubles.
    Essential Links:
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    Quote Originally Posted by Patrick_B View Post
    Like this?:
    http://goo.gl/0UT7Bd
    That would be great. Currently I have to hold the hose on with one hand while back-washing to prevent it from popping off.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Exactly. You can do it how you like, mine just happens to be female (that one) on my hose end. One will need a thread end...whichever you install on the system piping. Get a 2" camloc for this. Holding the hose end on there is for the birds!
    Essential Links:
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    Thanks that solves half my problem right there. How did you attach the hose to the camloc? One of those screw down clamps?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yep. Inserted the barb, wrapped the excess hose around barb, radiator hose clamp. Not even a drip. Not fancy, but works like a champ.
    Essential Links:
    30,419
    Not sure but I think the backwash discharge opening is the same diameter as 1.5" pvc pipe so a 90 would glue directly to it. Mine is hard-plumbed but I cannot remember (I'm not there right now) just what fittings were used but I know it's all glued pvc.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,994
    My backwash port is standard size, and someone in the past glued an elbow and a threaded adaptor onto it. I screwed one of these in and I attach the roll-up hose with one of these.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Mine too, I just came out with some thread for flexibility. They ought to thread the multi port outlet, but they forgot to call and ask me.
    Essential Links:
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    Mine already has a threaded adapter that looks a little like this
    I will try to take a picture of it later today when I get home. Not very handy and I don't really have the correct vocabulary either.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    No problem, we'll help you.
    That is called a barb fitting. Two sizes on that one. If it's already there and big enough, you can hose clamp your backwash tube to it if you like. All you'd need then is the hose clamp.
    Essential Links:
    Mar 2011
    441
    There is no reason you can't backwash into a rain barrel and use it to irrigate.
    20X40 30,000 gallon gunite pool
