Results 1 to 10 of 10
Thread: Sacrificial Anode needed???
    Feb 2014
    Upstate, NY
    390
    Hello guys, I recently converted to SWG. Is it necessary to install a Sacrificial Anode ??? I mean do they work ??? I believe they are installed in the skimmer basket.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Re: Sacrificial Anode neede???
    Unless you have aluminum in contact with the water (common only on automatic pool covers) there is not normally any reason to install an anode.
    Feb 2014
    Upstate, NY
    390
    Aahh, thanks Jason !!! Interesting.... My PB just called to schedule an opening of the pool. Wanted to sell me all kinds of chemicals. I told them I just installed a SWG. They said I need a sacrificial anode installed in the skimmer basket, 22.00. I was just curious. I mean 22.00 will not hurt, I just wanted your opinions. Thank you.
    Feb 2014
    Upstate, NY
    390
    Anyone on the forum actually using the Anode???
    Jan 2012
    'burbs of Augusta, Georgia
    7,239
    I've got to admit, everytime anode talk rolls around here I get nervous. I have an automatic cover. I have no idea if I have an anode?
    Feb 2014
    Upstate, NY
    390
    Quote Originally Posted by YippeeSkippy View Post
    Seems to be a bit of a "Gray" area.
    Feb 2011
    Petaluma, Ca
    665
    They put one in my pool filter system, drilled a hole in the pipe and clamped this device around the pipe so the water goes through around the anode, it doesn't look much different now than when they put it on.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Feb 2014
    Upstate, NY
    390
    Re: Sacrificial Anode needed???
    Thanks Bobby. What doesn't look different ??
    Feb 2011
    Petaluma, Ca
    665
    It doesn't look like the anode is all corroded or anything looks about the same as when it was installed approx 2 years ago.
    Feb 2014
    Upstate, NY
    390
    Wow, thanks for the pics!!! The experts on this site did say they are not normally installed and/or needed. I appreciate the feedback on this.
