Thread: Cracked Pentair light niche
    Apr 2015
    Abbeville, South carolina
    4
    Hello All,
    I had an 18X36 vinyl lined pool installed last May with a Pentair light niche. First repair was made in June as leak detectors said a leak was around the light niche conduit. They installed a grommet and underwater epoxy for this fix. Well five weeks ago I removed my cover and the water was below the light. Since then a new niche has been installed, per removing the leaking niche it has about 9 slits in it. It looks as if it has been cut with a razor knife. My pool builder in now saying this was caused by lightning and wanting me to file a home owner’s claim. I find this hard to believe as I have seen others having Pentair niche cracking issues.
    Last but now least I am still trying to determine if the new niche is not leaking. I have not cover up the hole we had to cut in the concrete and water is still gathering in this hole. Of course my pool guy is saying this is ground water seeping into the hole. It is about 2 gallons per 24 hours so it is hard to say at this point if it is pool or ground water. What a mess I have at this point…… Any suggestions or ideas?????
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Cracked Pentair light niche
    Welcome to the forum.
    Sorry I don't, but the lightning sounds a little far fetched. Perhaps a bump to your thread will get you some suggestions.
    Essential Links:
    Apr 2015
    4
    Any one have any ideas on this? Thanks.....
    Apr 2015
    4
    Has anyone ever had this issue?
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    If possible, try digging a similar depth hole several feet away from the existing hole. I would think 10' should be far enough away to avoid any pool leakage yet close enough to to see if you have a high water table. If it is ground water, that hole should also fill up at the same rate. If it does not fill up, then you have a leak.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
