Results 1 to 11 of 11
Thread: acceptable water loss
    Sep 2014
    Bluffton/IN
    52
    Losing about an inch over 14ish hours. Is this normal or should I be concerned about a leak?
    In-ground fiberglass hybrid (25K gal), Raypak Natural Gas, Hayward S-244S Sand filter, AquaRite SWG
    NE Indiana TF-100 test kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: acceptable water loss
    Yes, that is excessively high.
    Essential Links:
    Sep 2014
    Bluffton/IN
    52
    Suggestions on where to begin to find the leak?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    First, see if it stops leaking/losing level when it drops below the skimmers. But aren't you in a SLAM right now? Sorry, answering lots of posts right now.
    Essential Links:
    Sep 2014
    Bluffton/IN
    52
    No problem. I have not begun the slam yet since I am seeing such drastic improvements
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    If it stops once you get below the skimmers, then that tells you something.
    Essential Links:
    Sep 2014
    Bluffton/IN
    52
    Ok, pump has been shut off for 2 days now and it looks like the water has stopped going down BUT it is still about 1/2 in above the skimmers. I looked around the edge and dont see noticeable cracks. Could it be going through the seems on the sidewall? Any suggestions?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    I don't have any experience with leak detection. Yet ...
    But, here are a couple of article from Pool School about leaks. Hopefully they will help.
    http://www.troublefreepool.com/conte...leak-detection
    http://www.troublefreepool.com/conte...side-air-leaks
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Quote Originally Posted by february17th View Post
    Did it continue to drop after the pump was shut off, or did it stop then? It's really common to have a leaking multiport valve, and if it's hard-plumbed to the sewer or discharges some distance away, you might not notice the trickle of water.
    Sep 2014
    Bluffton/IN
    52
    Richard, I am not sure where/what the muliport is! It seemed like the water stopped with about a half inch above the skimmer's. I turned the pump back on and it took the water barely below the skimmers so I turned it off again. Once I did that water level went back to 1/2 in above skimmers....odd as I would think the pipes would be full of water if above skimmers....correct?
    The water seemed to stop about 1/2 in below the return jet. Could this be where the leak is? Do I fill again and do the food coloring thing?
    If its in the pipes below the concrete, what are my options?
    ok I found out what the mulitport valve is. I discharge the waste to a tile about 2 feet away so I dont think its that
    Richard320's Avatar
    Jan 2010
    19,009
    I'm not understanding something. The returns are usually below the skimmers. Water dropping in the skimmers when the pump is on is normal if the water level is low. That I understand. The thing with the returns is what has me confused.
    Bear in mind that water seeks its own level. So if the leaking stops at some point, the leak is right at that height. I have no experience with underground plumbing repairs, so I have no answer there.
