Results 1 to 20 of 20
Thread: The forum is acting up today
    The forum software has been acting up today (and a little bit yesterday). I am aware of the problem and I am looking into it.
    For the moment the slideshow on the home page is disabled. I hope to have it restored shortly.
    Hopefully this whole issue will be straightened out soon.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: The forum is acting up today
    Noticed that this morning as well.
    Essential Links:
    The slideshow is now back, and things are working for the moment. However, I don't think I have found the root cause just yet. So things may remain a little unstable for the moment.
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Yesterday I got server is busy, try again later message - if that helps.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Yep, that is one of the symptoms. I am also seeing page loads which just timeout. Trying again right away often works when there is a problem.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    I just automatically assumed it was something Patrick did........................
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by woodyp View Post
    Essential Links:
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    So we are back up?
    Essential Links:
    Well, yes and no. I have been adjusting some settings to try and stop the problems, and the current combination seems to be working, but I still haven't pinned down exactly what is causing the problems in the first place.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Thanks for the work Jason.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Good job fixing Patrick's mess, man!
    38,248
    I noticed my phone being REALLY slow this morning a few hours ago. But being that my phone is a POS and I was using Tapatalk and I would not put it past Verizon to throttle me, I thought one of those could be the culprit. Although then I went to another forum and things seemed to be working at normal speed.
    I am sure Jason will figure it out eventually
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Right now, it's smoother and quicker for me on iPhone than its been in 4-5? Days.
    Essential Links:
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Have you checked your router logs to see if you are under a DOS or DDOS attack?
    Did the software undergo an automatic update? If nothing has changed on the forum software it is unlikely to be the cause. If it is hosted on a Windows server check the application logs on the server.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    DFW, TX
    24,450
    Hmmm, I thought we were under Patrick_B west texas pollen attack.
    Part of what was happening was an HTML flood attack, but there was another component I am still not able to pin down.
    Smykowski's Avatar
    Sep 2011
    3,065
    Just got a "The Forum is Busy Right Now" error on Tapatalk.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Not seen it yet thankfully, but that's how it started end of last week for me.
    Quote Originally Posted by JasonLion View Post
    Can you explain that in non IT Savvy terms?
    Essential Links:
    People sometimes setup computers (robots) to attack web servers. There are many different ways to do this. The trouble this week was mostly caused by someone setting up a robot to access web pages on our site very quickly, loading down the server, causing slow response times and eventually triggering what is basically a "server overloaded" error message. Once I found that part of what was happening, it was easy to block them.
    By the by, I am expecting normal traffic to saturate the server soon, and plan a hardware upgrade for early May. Depending on how rapidly traffic rises this spring, we may get overloaded at some times here and there before the hardware upgrade is in place.
  20. Back To Top    #20
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Robots...ok. Still a little bit like the Wild West on the Internet.
    Thanks for the info, all good to know.
    Essential Links:
