Results 1 to 7 of 7
Thread: ground prep/tilted pool
    Apr 2015
    Murrieta/CA
    3
    I have 14' above ground Intex pool. Last summer I set it up. The level was off by 1" which I believed was okay. Through the summer I noticed it start to lean(of course) to the downhill side. It got worse and worse and one day I went outside and the uphill side legs were 6-8 " off the ground. I drained the pool and stored it figuring I would try again next year assuming I must have been wrong about that one inch off level. Now I am ready to do it again but right this time. So I check and sure enough it's only off by 1" Any comments on that are welcome but my question is what is the best method for leveling? I was planning on digging the one side down 3" and the other 2" and then fill with sand. It's just a dirt area, no grass. any suggestions are greatly appreciated.
    14' Above ground Intex pool
    Casey's Avatar
    SW PA
    10,453
    Re: ground prep/tilted pool
    Start at the lowest point with a 4ft level until you are level the whole way around.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum ysrider
    Did you have any kind of a footing like a paver under the legs to keep them from sinking in. Did the downhill side legs look like they had "dug in" when you took the pool down ??
    Solar Blanket, Well Water, Borax Added. 68
    Apr 2015
    Murrieta/CA
    3
    I did not have anything under the feet. The dirt was very solid. The feet hardly dented the ground. I plan on putting pavers this time because I will be disturbing the soil.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Hopefully someone with AGP experience will jump in.
    Jun 2012
    MA
    347
    What is off by 1". How are you measuring the 1"? Your post makes no sense.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,549
    Most (all?) people here will advise against this, but here's how I dealt with an 8" drop in my yard.
    http://www.troublefreepool.com/showthread.php?t=73741
    Going on 4 years now and it's still perfectly level.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
